Evaporator Coil I have a Goodman A/C system (2 systems...1 for 1st floor, 1 for 2nd floor). The one for downstairs is 3.5 ton. the one for 2nd floor is 3 ton unit. Installed when house was built 5 1/2 years ago. The upstairs unit has had the evap coil replaced once, and repaired a leak once - 6 months ago. The downstairs unit has had the evap coil replaced twice -and is now leaking again. Model for the air handler is ARUF042-00A-1A. Goodman part# for the coil is P140142. Can I replace this coil with any other manufacturers coil ??? VERY tight space.Help.
  • 236 Answers
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Posted on Sep 11, 2008
What it means 450 PSI on ADP evaporated coil
THIS WOULD BE THE TEST PRESSURE AT FACTORY. UNDER NO CONDITIONS SHOULD NOT EXCEED THIS PRESSURE!
Jul 10, 2014 | Goodman Manufacturing Goodman CAPF3642C6...
2 ton unit
6719f81e-d5d1-47c4-b80f-e11712a6cac5.pngNo oversizing the condenser will not work well, however oversizing the evaporator coil by 1/2 a ton actually increases the units efficiency and is recommended to do by most utilities on units they finance.
Jul 07, 2013 | Goodman CKL36AR36 Air Conditioner
How to change a evep coil from a up flowunit to a down flow
What I have seen in the past and I have a few pictures, is you literally turn the entire Air handler upside down and insert the evaporator coil in so it would then be considered downflow, most ac companies have addition info in case you need any additional breacket etc.
Hope this helps.
Jun 02, 2013 | Goodman Manufacturing...
What is the correct size for evaporator coils piston ?
.078 is Shipped with Coil
Note: For a properly matched system and piston sizing information, refer to Goodman piston kit chart of the corresponding Goodman
outdoor
unit.
Oct 26, 2012 | Goodman Manufacturing Goodman CAPF3642C6...
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I have an aruf036-00a-1a and have been told the evaporator coil is leaking. The unit is approximately 7 years old. Do I need to buy the whole box with blower and all or can I just purchase the evaporator...
The evaporator coil can be purchased separately and is the most common part to leak on an a/c system. The system must be evacuated of refrigerant and the old coil cut out and the new installed. Leak check performed and vacuum pulled on the system before recharging with refrigerant.
Jun 26, 2011 | Goodman Heating & Cooling
Do you know how I can get a Goodman Ht pmp Manual
this manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Oct 01, 2009 | Goodman Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
437 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
