Question about HP Pavilion dv9000z Notebook
Will not start up
Comp worked great up until today with no problems at all. Then shut it down completely and now it will not start up. When i push the power button the lights come on and the whirring of the drive and possibly the fan start (normal stuff) then the whirring stops after about 5 seconds. After waiting about 15 seconds the computer shuts itself off. Upon pushing the power button again the lights will flash and it shuts itself off in about 3 seconds with no attempt to start up.
  • limicolous2 Nov 24, 2008
    i have the same problem with my dv9010us , i press the power button , the lights blink then go out, hear a faint beep, the fan tries to com one, 2 wer wer's out of the hard drive and then it shuts of or just sits there, in the cycle of trying to boot sometimes. resetted memory, pulled hardrive it works fine, used another battery and ac adaptor. its out of warrenty of course by 2 months, i have no idea how to fix it.
  • browncow17 Nov 25, 2008
    My Lights come on but nobody's home - no beeping or anything - and the lights stay on. I'm going to try taking everything out like suggested. It was fine and than all the sudden locked up, I attempted to reboot and kaput.
  • 71 Answers
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Posted on Sep 09, 2008
My 1998 delta 88 died again today. While driving it just shut down completely. No battery power no nothing. After having it towed it started like nothing was wrong an hour or so later. Have had the pr
Battery connections good , battery ground cable connection on the frame an engine clean an tight ? No corrosion . I wouldn't look for any ground issues under your seat . No power , main cable problem , to starter etc...
Feb 23, 2018 | 1998 Oldsmobile 88
Complete Shut Down
These HP's are notorious for Formatter (main board) problems. probably not worth fixing.
Aug 17, 2009 | HP LaserJet P2015 Printer
My 1992 Trans Sport starts then shuts off right away
fuel problem somewhere along the line¿¿¿ but where ,i would remove the tank sender unit and check the pump and pump flexible connection first
Aug 14, 2009 | 1992 Pontiac Trans Sport
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 | Garden
Keeps turning off
Sounds like a hardware failure. Possilbly the motherboard, more than likely, the power supply.
But then - maybe neither.
Shut it off completely, once you restart, start hitting the F8 key ( once a second ) until you see the " Safe Mode" choices screen. Drop down and select the " Last known Good Configuration" option and hit enter.
If this doesnt work, try the same proceedures ( restart - F8 ) but this time select safe mode - at the top of the list.
If you sucessfully boot in safe mode, you have a system file problem that could be virus related, file table corruptions or registry problems or all combined.
We're here if you need us.
Oct 10, 2008 | MSI PT880 Neo FSR Motherboard
I have a RCA Tv i bought several years ago and up until now it worked great. But it turns itself on and off and switchs through the channels on CATV before shutting down.
the push button switches are bad. you need to have the switches replaced to fix this common problem. the switches get corrosion and start making contact themselves with out being pushed by you causing all kinds of problems.. Your power and channel up and down switches are obviously the ones going bad first.
Aug 02, 2008 | Televison & Video
Case fan runs on standby
If your case fan uses a 4pin molex instead of a three pin which pluges in to the board. Than that's why it only shuts off when the system is powered down.
View molex.
How to vote you're expert.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Garmin nuvi 250w freeze up
EXact same model and exactly the same problem for me.
Mar 04, 2008 | GPS
The PC doesn't completely boot up
u shoudl use xp cd and boot in formatt hard drive fresh install of your os
Jan 28, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion dv9000z Notebook Logo
185 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
