Question about Epson Stylus CX5400 All-In-One InkJet Printer
PICTURE IS SO LIGHT YOU CAN'T MAKE IT OUT
KODAKSHARE G610 PRINTER DOCK .PUT NEW INK CARTRIDGE TODAY WILL NOT WORK . WAS DOING FINE
  • Epson Master
  • 691 Answers
Did you use genuine ink?. Are there any tapes/bungs that need to be removed? Have you run a cleaning cycle to ensure ink is bled through?
Posted on Sep 19, 2008
My printer is only printing half the picture, one half comes out great and the other half has nothing
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
    NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists cal 1800 2356325 > for a repair
Oct 26, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
Can't remove used ink cartridge from G600 Printer dock???
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
No color in pictures
We had a similar problem and found out that we put in regular photo paper by mistake. You must use the paper that came with the cartridge because the printer dock uses a thermal heat to produce photos. After using that paper the photos were great.
Jan 21, 2009 | Kodak EASYSHARE G610 Thermal Printer
Easyshare g610 printer dock doesen't work
You need a new AC adapter, they are available on eBay. I have replaced many of them.
Jan 19, 2009 | Kodak EASYSHARE G610 Thermal Printer
Ink cartridge won't go in.
Normal 0 Double check to make sure you have the right cartridge for the printer. This is a common mistake people are making. It’s easy to do.
Hope this helps. Bud
Jan 06, 2009 | Kodak EASYSHARE G610 Thermal Printer
Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Jan 03, 2009 | Lexmark All-in-One Printer with PictBridge
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
Mar 27, 2008 | Kodak EasyShare Color Photo Printer Dock
Epson Stylus CX5400 All-In-One InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
