Question about Sanyo DS31520 31" TV
Sanyo model DP26648 (or dp32648) won't receive digital signal
We don't have cable. We just bought this new TV, our first Sanyo, and we can't receive a signal from the local public station, which is only broadcasting now in digital. We get the other local channels, both analog and digital versions (I think)
4 Suggested Answers
  • 520 Answers
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Posted on Jun 28, 2008
  • 360 Answers
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Posted on Jan 29, 2009
memturbo
  • 226 Answers
SOURCE: Digital channels
It's possible the stations you have in your area
have switched from UHF to VHF or vise-versa
I had the same problem and have lost one channel completely
You didn't clarify if your using an antenna or
cable qam so I assumed you are using antenna.
Youll need to check your antenna to see if it
supports both UHF vhf if it only supports one
that could be your problem .
go to antennaweb.org it will help you determine
what stations are avalible to you .
Posted on Jun 13, 2009
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
We bought a 32" Sanyo LCD Hi-Dif digital
We do not sell parts through fixya. However, shopjimmy.com, http://www.shopjimmy.com/catalogsearch/result/?q=DP26648, has many parts for the DP26648 from TVs that were damaged in shipping. These are used but have only been run during QC testing at the factory. The power supply is listed as out of stock but lists for $64 when they have it.
Some other Sanyo TV parts are available here: http://www.partandproducts.net/sanyo-tv-parts.html . This site also lists the power supply as out of stock.
I hope this helps.
Apr 11, 2011 | Sanyo Televison & Video
Looking for new or used main motherboard
Required main board for Sanyo DP26648 lcd tv is available in Shop Jimmy.com for $70
Click to view image of board, make sure your tv model is as shown in your question headings.
Thanks.
Oct 23, 2010 | Sanyo DP26648 LCD TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Just bought new 32" sanyo model dp32648. Can't get the picture or
If this problem is happening on a regular TV channel and does not appear when watching an HD channel or while watching a DVD then most likely you have no problem at all. What you are seeing is actually the LOW Definition signal sent for regular TV programming that used to look pretty good on a small tube style screen but now is enlarged on a screen capable of incredible accuracy and is displaying all of the poor quality attributes of standard definition TV.
Feb 25, 2009 | Sanyo DP32648 32 in. LCD TV
Sanyo DP26648 cable problems
I have a sanyo dp26648, just had it over 90 days and it quit. I can hear the sound, but no picture at all. Just a bright white screen. I can't even go to the menu. I bought the extended warranty but there in not anyone in my area to fix it. They told me I would have to wait until they found one close.
momdukes
Sep 10, 2008 | Sanyo HT32546A 32 in. Television
Set up lcd tv
Make sure of correct input
HDMI is best
cable box must be set to HDMI
otherwise input to channel 3
Jul 22, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo DS31520 31" TV Logo
108 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
