Question about Toshiba SD-220E DVD Player
Disc loading, playing and then freezing
My Toshiba SD-210E loads dvds and will play but gets stuck after about a minute. The player sounds as though it is struggling to access the disc. I can skip chapters, it plays for a few seconds then sticks again.
  • susanmrt Feb 01, 2009
    Okay...since there are no little men inside, how do I re-lubricate the system?
    Thank you,
    Susanmrt
    President:
  • 3,130 Answers
Sounds as though you may have a slider problem or something is blocking it. The slider is what holds the laser assy as it slides along it like a rail while the motor drives the slider by a gear shaft system or a belt system.. I've seen in the past the grease or lubercation on this slider can harden up and ive also seen something getting inside like paper or little army men who wanted to hide out and was assisted there by a wee one. although these are common, another problem is that the tracking curcuit could also have a fault like alighnment or defective part now that would also include the tracking or slider motor too. Good luck
Posted on Mar 28, 2006
SOURCE:
Won't play dvds
The DVD play part has probably had it. Try putting in a CD cleaner disc (a special CD with nylon brushes on it) if you want to spend time on it, this can fix some dirt on lens problems. I would just go and but the cheapest supermarket DVD player to replace it, why the cheapest? because DVD/CD players never last very long before they fail like this.
Dec 14, 2013 | Toshiba SD-V296 DVD Player/VCR
I cant play some blu-ray disc how can i get some of them to work
since it doesn't have enough RAM in it, some BDs or larger multi-layer DVDs fail to play/load entirely Its slow to buffer BD, and even slower to upscale DVDs. It doesn't support homemade DVD+/-R movies. It also doesn't support video on CD.
SOLUTION:
to get the movie to play add a 4GB SD card into it and format it for use as extra memory. Apparently, some BDs require a lot of memory. By adding the SD card, DVDs and THE BDs load faster and have no play problems. The overall downside to the RAM issues and the SD card is that, when the SD card gets full,you will have to reformat it to get anything to play. Tho, all lost disc info needs to be rebuffered onto the card the next time you watch the movie.
Mar 06, 2011 | Toshiba BDX2000 Blu-Ray Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
WHEN DVD IS PLACED IN MACHINE IT KEEPS TRYING TO LOAD BUT NO PLAY
yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Mar 29, 2009 | Toshiba SD-5000
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba SD-43HK Discs failing to load.
Sorry not a solution but experienced the same problem. The problem started off the same as you described by now my player won't play DVDs at all. Seems that the laser is faulty and it is cost prohibitive to repair (it's sold as a complete module which would be around £100). I've been advised to replace it :-(
Jan 16, 2007 | Toshiba SD-43HTS System
Toshiba SD-220E DVD Player Logo
305 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
