Question about Chem USA ChemBook 4027 Notebook
Nobilis laptop model cy27
I am trying to remove the screen off of the above laptop but i can't seem to get the screen to detach from the base of the computer. I have removed all screws and still it won't move.
Can you help.
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
How to detach TV TH42PE30 from its stand TY-ST42PX20
There are four horizontal phillips screws (two at the end of the base plate directly above it and two a couple of inches above them) that are a slightly bigger diameter. Remove them completely and base plate slides right out.
Jun 30, 2011 | Televison & Video
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
Nobilis laptop overheat?
Nobilis Has HEAPS OF PROBLEMS! take it to an expert computer shop and they will fix it.
Apr 21, 2009 | Computers & Internet
Replacing screen on toshiba sattilite a215-s6816
There are screws that fix the hinges to the base of the laptop, usually two screws per hinge and these are located on the back of the laptop, remove them. Remove the panel on the laptop that is adjacent to the bottom edge of the LCD screen, this may be a single part of the plastic around the keyboard, may have to remove the screws on the bottom of the laptop, carefully unclip the plastic surround around the keyboard.
There will be two connectors attached to the LCD, one for the video signals and the other for the backlight power, near the bottom edge of the LCD screen, detach these before you remove the LCD.
Dec 30, 2008 | Toshiba Satellite PSAFGU-048002 Notebook
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Replace Keyboard for Acer Laptop 2414WLCi
Hey,
Here it is step by step. (Depending on make and model, disassembly may vary slightly.)
1) Remove the battery.
2) Remove ALL of the screws from the bottom of the laptop.
3) Remove any screws on the back of the laptop.
4) Fold the screen back as far as possible then remove the small plastic caps on the hinges.
5) Remove the piece above the keyboard, with the power button on it.
6) Lightly lift up the keyboard and underneath it you will find a ribbon cable attached to the motherboard, detach the keyboard and replace it with the new one.
7) Do exactly the opposite of what you just did to reassemble.
:) Hope I helped!
Feb 26, 2008 | Acer TravelMate 2300 Notebook
Chem USA ChemBook 4027 Notebook Logo
661 people viewed this question
Top Chem USA Computers & Internet Experts
David Payne
David Payne
Are you a Chem USA Computer and Internet Expert? Answer questions, earn points and help others
