Question about Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3 volume control/power know gone bad
Hi, I was wondering if you can guide me on how do i go about opening the altec lansing atp3 speaker and change the power / volume control knob. I guess that while packing it the woofer lied over it and that has damaged the volume control know. could you please guide me on how to open it so that i can replace the know. i am not able to find the right way to open that speakers. Thank you Kevin
  • mleusink Nov 09, 2007
    I would also like to know how to open the Altec Lansing ATP3 speaker. The one I'm interested in is the satellite speaker with the volume knobs. I can't find any screws anywhere (there are no stickers to hide under, they're not under the rubber feet in the bottom, and they're not behind the netting on the front of the speaker). If anyone has opened this speaker before, I'd really appreciate your assistance.
    Thanks,
    Mark
  • livescu May 11, 2010
    The Best Solution posted here doesn't help me at all. I have the same problem in opening the satellite speaker with the volume knobs from the Altec Lansing ATP3 system. The volume is unstable and I suspect the volume knob to be defective. There are no screws anywhere you look and there is no removable net (all is plastic in one piece, except the cover under the speaker). I tried to pull out the cover under the speaker by force but if I would force more I could brake it. Does any of you already open this speaker, please?
    Many Thanks,
    Liviu
    Problem Solver:
  • 10 Answers
Just sone it, i had to break a whole in the bottom part , work my way around it with a screwdriver , it will snap every 2-3 cm and come off in the end.
after its off start at the (now exposed) bottom of the front bit and work your way up and aroud `till it comes off. mind the wires . as for the volume button fix , as soon as i played with it and tried it again , everything was good. even though replacing it doesn`t seem like a big deal
put it back together and will superglue it in the future( while typing this i doubt if it will ever happen), and it lookes good( except from the bottom ,where its broken !).
now the button is solid and the sound as well.
SWEET
SWEET
Posted on Nov 05, 2009
Hi i used to have the same problem opening the satellite speakers of atp3 (left satellite, the cord was pulled and snap from the inside). i found out how to open them but there's a good and bad news. the good news is i know how to open them, the bad news is that it will cause some damage on your satellite speaker.a friend of mine used to have the same speaker he accidentally drop one of his satellite speaker (left one) and the bottom cover just crack open following the joint line.
the satellite speakers of atp3 has no connecting screws , it is assembled using a sort of super glue. here is how i opened my satellite speaker.
i used a flat screw driver (i sharpened it a bit to easily penetrate the joint) to shove the bottom cover of the speaker starting from the back part (near the cord) then slowly made my way around when the cover start to snap from where i started. you can remove the bottom cover this way but be aware that it will cause some damage on you speaker. i started shoving from the bottom back part because the damage is unnoticed when you reassemble it using a super glue and i use a black paint to hide the discolored plastic casing cause by force opening.
i hope this help a bit
J3n c",)
Posted on Mar 07, 2008
    Champion:
  • 277 Answers
Hi im familier with this system but i dont excactly remember where are the screws however the opening methods are all alike look for any screws any where on the speaker look behind the net if thereare any if there are gently shove a flat screwdriver and lift out the net then after all the screws are out there is a small slot souronding the speaker gently shove a flat screwdriver in the corner of the speaker untill there is a small gap do the same for all corners there might be another hook in the middle that it good luck do the same
Posted on Apr 17, 2006
2 Suggested Answers
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
My altec lansing atp3 pc speaker have no power
check the power adapter if its faulty replace it
Jul 31, 2011 | Altec Lansing ATP 3W Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
How to repair atp3 altec lansing
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3
there is a lose connection near the main speaker .When i move it sound stops
Dec 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
5,994 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
