Question about iLO (2 GB) MP3 Player
About my mp 3 player
Please backup the data and format the plyer
  • 8,596 Answers
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Posted on Sep 13, 2008
MP305 showing do u want to format it now..
I'm assuming you actually want to format the mp 3 player. To do that plug into computer click computer right click the drive the mp is plugged into and press format. All data would be deleted.
Nov 25, 2009 | Coby MP305 MP3 Player
How can i get my coby mp-610 stop saying file system error???
View MP-610:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
Manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Quick setup guide:
http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
File system error refers to incomplete startup often due to low battery, faulty firmware or not matching files in the player.
When the startup failed try point 1.Resetting and 2.Charging:
1. Try to reset using the reset button hole on the backside (8).
299c492.jpg 2. Make a connection with the computer and have the device charging for a long period, full load needs 8 hours. Make connection directly to the USB of the computer preferred at the backside of the computer.
When using a laptop see to it that the USB is powered: laptops often switch the USB off going to sleep op hibernate mode.
When this didn't solve the problem, perform a format and reinstall of the firmware, point 4 - 8:
4. Connect the player to the computer and backup your data to the computer using the Windows explorer: copy MUSIC, MOVIE, PHOTO and TEXT directory to a location on the computer.
5. Format the removable disc of the player in Windows explorer.
Check your removable disk having its full memory capacity free after format.
6. Download the firmware for the player: firmware download for MP-610 ( zip file ):
http://www.cobyusa.com/files/software/MP610_Firmware.zip
7. Unzip the file: once unzipped there's a pdf instruction added in the zip file how to perform the firmware update.
8. After the firmware reinstallation the player is ready for transferring
data again. Remember the requirements for the format of files that is put on the player.
Sep 23, 2009 | Coby MP-610 MP3 Player
Flash error - please backup the data and format the player?
how do i backup the dataup when it can't be seening by the pc
Feb 28, 2009 | MyMusix PD-6070 MP3 Player
Real player is not working
Do you have Nokia PC Suite installed on your PC ?  If you do, Follow the the following steps.
1. Backup your Phone using Nokia Content Copier.  2. Download Nokia Software Updater.  3. follow the instructions
Please note that using Nokia Software Updater or the *#7370# method will format the phone's C:\ Drive so Contacts and Messages will be lost.
Use Nokia Content Copier before attempting this
1. An Alternative means is the following.
Backup your data using Nokia Content Copier.  then dial *#7370#
Enter the lock code, by default the lock code is 12345
after that wait and attempt to use real player.
IF unsuccessful follow the first set of Steps.
**NokiaGeek91**
Feb 09, 2009 | Nokia N95 Cellular Phone
Have Question
the memory is corrupt and needs to be formated, plug the player into your computer, right click on the mp3 drive you see in my computer and select format.
Aug 25, 2008 | iLO MP3 Player
My 2 Gb ilo won't play my music
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 21, 2008 | iLO (2 GB) MP3 Player
Problem on mp-556
-Tha Mp3 Doctor
Jan 19, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 model mp-556
you must insert your mp3 into your usb port then click on My Computer icon, right click on mp3 drive and click format disk, this will resolve this problem.
Nov 29, 2007 | iLO MP3 Player
Mp3 player has an error
My Musix MP3 when turned on says flash error please backup the data and format the player. When I put it in the computer no message to tell me how to do this comes up. I don't have the manual anymore. Please advise.
Oct 24, 2007 | MyMusix PD-6070 MP3 Player
iLO (2 GB) MP3 Player Logo
24 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
