Question about Philips GoGear SA178 MP3 Player
Can't turn it on, l;ock switch isn't on
I tried to turn on my mps player today, but it won't come on, holding down the switch on the front isn't doing anything. it worked a few weeks ago. I received it last christmas as a present and haven't used it much.
  • foxyladyis Sep 15, 2008
    after playing with it I found that it had a battery case in the back. after replacing the battery everything is okay
  • Anonymous Sep 29, 2008
    where and how do i get to battery?
  • 8,596 Answers
Reset the PlayerUse the Philips Device Manager to perform a Repair
Posted on Sep 13, 2008
My key is stuck in the ingition switch of my 2003 isuzu axiom it will start the car and turn off to pass the acc point but won' t go to ock and come out
behind key switch youll find a cable just pull on it about 1/2 " it is connected to the button on the shifter easy to fix 1 screw must have fallen out
Oct 26, 2011 | 2002 Isuzu Axiom
My sansa mp3 player will not turn on
This happened to me today, which was what brought me here. Also, when I plugged it in to recharge, my computer didn't even recognize it. The SanDisk troubleshooting said to hold up a power switch, which I didn't have, for 20 seconds. So I held the power button down for 20 seconds. (Much longer than the usual amount of time required to turn on). At first I thought it didn't do anything, but then when I pressed the power button again briefly, my SansaClip woke up, was recognized by my computer again, and in every way behaved normally.
Jul 10, 2010 | SanDisk Sansa Clip MP3 Player
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
My device turns on but shows message ¨refresh database¨ it won´t do anything else, what can do?
HI,
Try these steps:
  STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and Install the Sansa Firmware Updater
Jan 29, 2009 | SanDisk Sansa e260 MP3 Player
WHEN I PLUG IN MY SA3245 NOTHING SHOWS UP ON THE COMPUTER MONITOR
OK to Disconnect just means ur battery is full and no files are in transfer to the device. After changing battery, the device will update fora minute, if after a decent ammount of time goes by and nuthing happens, use a pin and hold down the reset button, forcing the device to power down, turn it back on and try to let it update again
Dec 29, 2008 | Philips GoGear SA3245/37 Digital Media...
Sony BDP-S300.
I had the same problem and sent an email to Sony. Here's the answer (it worked) :
Go to page 53 of Operating Instructions Manual and reset the player as indicated.
If you do not have the manual, here's what to do : Press Power On button. Power On light will come up. Now, Looking at front panel you have (at right side) 5 switches : Play, Pause, Stop, Rewind, and Fast Forward. Stop is the center switch.
Now, with Power On light on (it lasts only about 30 seconds), HOLD DOWN the STOP button and PRESS POWER ON button (the power on light has to be ON). This will reset the player. It worked with mine one.
Jay
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
WONT TURN ON....
The thing is that after I put mps on my mp3 player i just leave it for a couple of minutes...depending of the size of the files and after that i start it up again and it works perfectly. Try it
Oct 29, 2008 | Sony Walkman NWZ-B105F MP3 Player
I can get my mps player to work opn my coputer and i tried my old mp3 player and it worked idk why its not working
Some Philips mp3 players are not compatible with Vista
go to www.usasupport.philips.com to see if yours is compatible
If you have XP:
1) Make sure you have installed the cd that came with the new player
2) Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 05, 2008 | Audio Players & Recorders
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
My mps player dont work
Call Philips - get it replaced. Seriously.
Mar 17, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear SA178 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
