Question about Jensen 200W AM/FM/CD Car Receiver - CD4610
FM RADIO DONT WORK..MODERATE AM
MADE ALL CONNECTIONS, PLUGGED IN ANTENNA BUT THE INDICATOR ON THE FACEPLATE SHOWS NO ANTENNA STRENGTH. IT SHOWS MODERATE AM ANTENNA STRENGTH, AND YOU CAN HEAR THE AM. ALL YOU CAN HEAR ON THE FM IS NOISE, ALL THREE BANDS. DOES THING NEED A MODULATOR FOR FM RECEPTION? DIDNT USE ANYTHING TO ADAPT ANTENNA PLUGGED RIGHT IN. DONT HAVE A SOLUTION, BUT FORGOT TO MENTION THE CD PLAYER WORKS GREAT. CAN U GUYS HELP??
  • 2 more comments
  • Anonymous Apr 24, 2008
    there is power to the unit. but the fm nor cd player will not work. any suggestions?
  • Anonymous May 29, 2008
    static am fm cd works fine replaced aerial checked wiring
  • Anonymous Nov 18, 2008
    same thing here... brand new car.. cant be the wire as stock headunit works fine
  • luru27 Mar 17, 2009
    I have the exact problem, did you find a fix?
  • 113 Answers
Typically when you can get am reception and can't get fm reception the problem is not the antenna but is in fact in the fm tuner- many times it turns out to be bad solder joints in the tuner itself
Posted on Mar 28, 2008
If you installed an aftermarket antenna you may have to splice two wires to make full connection, email customersupport@discountautoantennas.com and explain and they may be able to email you instructions for a solution you may not have it grounded properly.
Posted on Mar 14, 2007
    Champion:
  • 277 Answers
Hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Posted on Mar 27, 2006
3 Suggested Answers
SOURCE: Need a replacement faceplate for my mcd5110 jensen AM/FM CD player
I have the whole radio whithout a wire harness give me 50.00 and you will have a replacement radio in the future
Posted on Feb 19, 2008
SOURCE: FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
Posted on Jun 15, 2009
How do I get an antenna for the FM connection?
You can use an old rabbit ears style antenna or go to a radio shack and get a flat ribbon style. If you're close to the radio stations a single section of wire about 2 feet long connected to one of the antenna screws will work too.
Jan 03, 2016 | Kenwood Av Surround Receiver Vr-307
My brother gave me the receiver, it is a AV AVR 1905 Denon do not have the antenna so all I get is static.
Test and confirm if the amplifier is working with an imput source. If the fault is only a loss of FM/AM signals then try and connect an external antennae based on the signal strength in your area to confirm if there is a fault in the radio sectiion. You can conect a set of wires to the FM loop connection and keep it up , if the signal strength is very good it will give you the signal after a search. Memorise, set an external antennae with a proper setting to get the best clarity.
Sep 30, 2011 | Audio Players & Recorders
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
My Sony CDX-MP70 unit plays CDs and works on aux off my iPod but when I try to listen to am or fm it's nothing but static if I scan for a station it will just search forever, I took it apart but it all...
Check for a loose antenna connection, at the unit and where your antenna is attached to your car. Also, check fuses, some cars have 'powered amplified' antennas.
If those dont work, try resetting the unit. On most units there is a small pinhole behind the faceplate(not on the faceplate). Could also be the internal tuner has gone out...
Hope this helps
Aug 24, 2010 | Sony CDX-MP70 CD Player
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    I have the Delphi MyFi xm2go. It is not the newer version, SA10113. My problem...It is no longer transmitting to my car's FM radio. While it is sitting in the cradle in the car, it 's display shows that it...
    Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
    Jan 20, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
    Delphi SKYFi3 XM Radio Repeater
    You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
    Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
    Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
    SATELLITE RADIO WAREHOUSE
    Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
    Boss marine am fm cd reciever wont get fm radio
    it could be either the fm antenna connection or the fm tuner inside the radio.
    Mar 29, 2009 | Car Audio & Video
    FM output
    I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
    Aug 23, 2008 | Audiovox Xpress Satellite Radio Receiver...
    Connect sirius fm adapter to 2008 honda civic sedan radio
    You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
    This way you can switch it on any station to get rid of the static.
    You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
    Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
    Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
    Jensen 200W AM/FM/CD Car Receiver - CD4610 Logo
    651 people viewed this question
    Top Jensen Car Audio & Video Experts
    xxxxxx xxx
    Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
