Question about HP DesignJet 750c InkJet Printer
HP DesignJet 750C
After replacing the platen and overdrive assm on a HP 750C Plotter, the cutter wheel is giving me fits! About 2" or so from the right frame member that it must pass through, the top of the cutter wheel tilts toward the front of the plotter and jams against the frame. I tried the old overdrive assm and does the same thing. Any thoughts, David
Yes, I had the problem a week ago, it was a "Doooh" moment when I figured it out.
Your cutter is not where it is supposed to be. It should be OUTSIDE of the metal strip, and you almost certainly have it running in the groove on the inside. THe cutter wheel should have almost 1/2" overlap with the overdrive blade.
As the service manual says on reinstalling it "Ensure the cutter is over the overdrive blade".
I must have looked at it 10 times before it registered. THere is even a drawing. Not a clear one, until after you realize what is wrong.
Posted on Sep 16, 2008
  • jimKlessig Sep 16, 2008
    PS the drawing is on page 6-33 of the service manual.
What part do I need to replace
Hello. What you are describing is a failing component on the power supply. Some part is working momentarily and then heats up and fails. Replace the power supply and you will likely fix the plotter. Power supplies can be ordered from: 0950 2623R HP Designjet 700 750C 755CM Power Supply
Jul 20, 2015 | HP DesignJet 750c plus InkJet Printer
Hp 750c Designjet plotter system error 010030 00070b20
This is a problem with one of three
  • Trailing cable
  • main PCA
  • carriage assembly
Jul 09, 2012 | HP DesignJet 750c plus InkJet Printer
Designjet 750c doesn't print colour
first, print a self test, if it is not printed, you may have a problem in your carriage, replace it
Apr 11, 2010 | HP DesignJet 750c InkJet Printer
HP 750C Moved across country, bought a new iMac. Forgot how to set up plotter settings so the mac can find it. on the network. I remember having to make changes on the plotter, but can't remember what...
Hello, the plotter should be seen in your print and fax preferences (apple menu, system preferences, print and fax): In the print and fax preferences panel, you can click on "+" at the bottom left of the window, you should see your plotter appear in the window, and click on the "add" button Best regards
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c InkJet Printer Logo
239 people viewed this question
Ben Johnson
