Question about Samsung RS2578BB Side by Side Refrigerator
Ice maker doesn't work
It looks like the ice tray fills with water but doesn't turn over to empty the ice out. When more water is added to make more ice it just pours everywhere since the ice tray is not empty. I've tried to pull the ice maker out so I can look at it but it won't come out. There is a black foam covered piece that I can push up and it looks like the ice maker should be able to pull out when I do that but it won't come out.
Any help is greatly appreciated.
  • Anonymous Feb 01, 2009
    Ice tray has ice but will not dump ice also no water will come out.
  • Anonymous Mar 13, 2014
    the ice maker don't drop ice the water run all over each time have ice everywhere
  • 700 Answers
Try as little bit harder and the ice maker should pull out stright from the freezer. watch out for the holders they are on the back and they sometimes are broken if you are not carefull with them. there is also two wire that have to be unconected when you do this. they are moilex connectors and if you push the tabs they should pull apart real easily. Thanks for using FixYa And have a great new year.
Posted on Jan 01, 2009
Help, help , help, Please.
I have one of the REFRIGERATOR MODEL: RS267LASH made by SAMSUNG about two years old.
For the past few months, I found that all of the accumulated ice in my ice maker had slightly melted and re-froze together, causing the spiral coil to lock into place. I had to pick at the ice in order to free the bucket from the freezer and completely remove all the ice.
It looks like the ice tray fills with water but doesn't turn over sometimes to empty the ice out. When more water is added to make more ice is dispensed into the tray and it overflows down into the bucket, out the chute and all down underneath the ice tray.
Email: kentwa@gmail.com
Thank you
Posted on Jan 10, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
Ice maker not working.
If your water tray was empty check the water supply to the fridge .
you shouldn't fill it manually.
\if the water supply is turned on, then the operating solenoid that allows water into the tray is faulty.
Whoever repaired your fridge should be called back immediately.
Dec 02, 2014 | Refrigerators
Heating element ice maker refreigerator
This is not something that you can fix. This is a replacement issue. Order a new ice maker.
Jan 27, 2014 | Neff Dishwashers
Ice Maker Doesn't Work
Is there ice in the ice tray? If so the heater is not working to allow the scooper to push the ice out into the tray. If no ice in tray then the fill solenoid is not opening to allow water into the tray. Replace the solenoid.
Sep 19, 2017 | Refrigerators
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Sep 06, 2011 | Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Samsung RS2578BB Side by Side Refrigerator Logo
461 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
