Question about Sony KP-65WS500 65" Rear Projection Television
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
The TV turns off itself immediately after power on. the standby led blinks intermittently 5 times each 30 s. I opened the front and plugged the CRT guns one at a time (CG, CB or CR boards). Surprisingly, when powered on the TV stays up and doesn't anymore turn off itself. Could you help me locate the culprit circuit, please! Thanks!
  • 3 more comments
  • mniang38 Sep 09, 2008
    As the TV power on only with 1 CRT gun at a time, I tried to increase the screen volt with a small screw until the lines disappeared. I did with the blue, the green and the red CRT guns but once I plug them all, the TV can't stay up.Thanks!
  • mniang38 Sep 11, 2008
    I turn all 3 screen volts pots down to mini and then tweak them to 1/8 turns. But still the TV, shuts off itself and the standby button blinks 5 times. When I turn down those 3 pots below that 1/8 turns, the TV turns off itself but instead the standby led blinks 8 times. Thanks!
  • Mr2008 Dec 04, 2008
    I have only adjusted the blue. It is currently turned all the way down yet the screen stays blue. I can hear audio just fine, but the sceen is stuck in blue. Can you help?
    Thanks!
  • Mr2008 Dec 05, 2008
    Yes, my TV is doing the same thing. Red and green are working great. Blue seems to be over powered. Screen is completely blue, i can hear audio. I also have the voltage all the way down on the blue and it is still WAY too bright, cant see any picture. What can I do? Please help.
  • IamSuperman May 11, 2010
    How do you adjust screen volts our tv blinks 5 times and the dvi input from the blue ray looks like a 3d show
  • 10,594 Answers
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
5 blinks, Sony KP-65WS500 stays up only with one C - d90a778.jpg Need further help, please let me know.
Bye.
Posted on Sep 09, 2008
  • Shahid Electronics
    Shahid Electronics Sep 09, 2008
    volts should be decreased a bit on all 3 controls.
Blinking 6 times and will not turn on
hello No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
regards
shaun
Jan 28, 2010 | Sony KP-65WS500 65" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP65WS500 5 blinks
I think problem is in Protection circuit itself. Protection seems unstable in your tv that's why it doesn't give you chance to diagnose problem.
Try to isolate protection command and check tv.
Its an idea and hopefully it will work.
Sep 24, 2008 | Televison & Video
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
I am getting 5 blinks
If the whole screen turns a bright blue and shuts down then you may have a bad blue crt. This will need to be replaced plus adjustments/alignments. Get an authorized Sony servicer to do the repair. Good Luck
Jan 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
713 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
