Question about Sony Televison & Video
I HAVE A SONY BRAVIA WICH DOSE NOT COME ON, BUT THE STANBY INDICATOR IS FLASHING 3 TIMES STOPS AND STARTS AGAIN FOR THREE TIMES TO FLASS. CAN YOU PLEASE HELP
  • Sony Master
  • 8,617 Answers
I would need the model number of your sony in order to help you
Posted on Sep 10, 2008
  • Eugen Rares
    Eugen Rares Oct 22, 2011
    I have the same problem with Sony bravia kdl40bx4
    Sometimes when i turn on the tv the green led is on, after a few seconds i can see The Sony sigla....but after that the tv is restarting without to touch any buttons. When is restarting is making a big noise and sometimes restart several times.
    Also after i shut down the tv , after 2....maybe 3 minutes i can hear the sound from the last channel for 1-2 seconds.
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
The standby indicator is flashing 4 times on my sony bravia KDL55nx720 tv and will not start. Is there something that needs to be reset?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony bravia 52 red light flash 3 times
Three flashes indicate a power board problem.
Hope this helps.
Dec 31, 2013 | Televison & Video
Sony Bravia stopped
press the power button once and then look for a flashing light that will give you some kind of indication of what your problem is the light should tell you a short code such as it will flash threee times then once or 2 times then 3 then 1 or sumthing along thos lines then you must refer to you owners manual and look under the troubleshooting for info on you problem
hope this helps :)
Oct 20, 2012 | Sony BRAVIA KDL-32V2000 32 in. LCD...
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia goes into standby mode blinks 13 times in sequence
standby light flashing is an indication that tv needs service. it prevents the tv from further damage. go to www.eservice.sony.com to check service options
Oct 01, 2010 | Televison & Video
SONY BRAVIA 50IN KDF E50A12U
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Sep 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Bravia KDL-40S2000 40 inch
We have the same problem.. Checked the Sony site after a few clicks got to: http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=966,E=0000000000761838071,K=1708,Sxi=1,Case=obj(460991),VARSET_OBJ=460991,VARSET_TSRC=results,UseTemplate=case.tem,VARSET_TOP=TRUE
We followed the 'simple' troubleshooting tips then called the service center. As mentioned above 4 blinks indicates a bad panel. The repairman that visited said that he is ordering a new power supply (much cheaper than the back panel) for their first try. I will post again when my set is back on.
Jan 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
