Question about JBL MR-4 AM / FM / CD 180 Watts Marine Receiver
Problem with compact dic player
So awhile ago the unit came detached from our spa, and not knowing how it hooked back on, I somehow got it to continue working, but now, I can't get it to work at all. The entire unit came off, and now, even properly securing it into position, doesnt work. It doesnt get any kind of power.
    President:
  • 3,130 Answers
Contact your installer of the spa they will determine what needs to be done as I dont have enough info to assit you
Posted on Apr 02, 2006
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
There is a slight shock when I touch top of the water. I am afraid to get in. What could cause a shock?
The Spa is not grounded and bonded properly....find a GOOD electrician that knows how to ground and bond your spa... he will drive ground rods specifically to just ground your unit...and hook them up so that there is no chance of stray voltage...
heatman101
Aug 23, 2010 | Hayward Comfort Zone Electric Spa Heater...
My machine starts to cycle and then it stops waits awhile then I get an error code F35. The machine will start and run without a load in it and cycles ok I can change to heavy duty cylce and it will run....
Hi, F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit.
Take care
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
How to hook up detached dishwasher to faucet?
Hello there:
you are going to want to make sure that the threads on the hose match the faucet and also make sure that the gasket is in place you might even need to get a adapter for the unit to hook up to the faucet.
i would consult the manufacture or the users guide for further help
Aug 08, 2009 | Danby DDW1805W Designer Series...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
LD 37LC7D
This set has a modification that needs to be done. It will also start turning on by itself and changing channels rapidly. It's two weeks old. Take it back to the Retailer or if that is not an option contact LG at 1-800-243-0000 to get a local servicer in your area.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Ribbon cable...
It would be cheaper to replace the unit. Be more careful next time with your equipment
May 13, 2007 | Phase Linear UMP8015 CD Player/Receiver...
Car Audio & Video Logo
88 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Rob Beech
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
