Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
  • Matt Walsh Dec 08, 2008
    I have a Ministry of sound mixer. The left turntable volume slider (verticle slider) is fine but the right turntable volume slider (vertical slider) does not work, it only works if i push down on it, its as if it has come out of place??
I had this issue and sent my mixer to a repair shop. They diagnosed it as a faulty poteniometer pot. This was according to them a know issue due t the design of the Pots Pioneer use. They replaced the pot and it now works fine...
Posted on Sep 03, 2012
  • 682 Answers
Apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Posted on Sep 23, 2008
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer djm 500 trims not working properly
The rotary controls / pot's (especially "low") on DJM500's are nototious for becoming dry jointed, usually a quick resolder of the legs / connections sorts them out.
http://stores.ebay.co.uk/methleykev
Jan 10, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Master channel problem
There is a master gain volume on the rear of the unit. Make sure this is not maxed out. Keep it between 1/2 to 3/4's of the ay up.
If this does not solve your problem, your going to have to give me more details. What do you mean when you say "moved off 0 peaks red on left"? Do you mean that when you lower the master volume, the left signal is still hot (red)?
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 30, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600 - fader panel not working
i would recommend checking a fuse somthing with such good quality would less liky need a replace ment unless the power cut really damaged it internily
Oct 06, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
577 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
