Question about T-Mobile Sidekick ID Cellular Phone
Wont turn on
My sidekick iD is charging, and theres an orange light, but how do i get it to turn on?
Call tmobile or watever phone company you have and ask for a new battery. Same thing happened to me and when I switched batteries it worked.
Posted on Sep 30, 2008
    President:
  • 625 Answers
The sidekick ID has the similiar problem that the sidkeick 3 did. The charging port can go bad. If the orange light is on, but the screen does not show the charging message or unit will not power on at all then it is probably bad.
Do you have a friend that has a sidekick id or sidkeick 3? Borrow their battery and test your phone to make sure it works.
An easy work around is to get a cradle that has external battery charrger. They are about 25 dollars on ebay and let you charge the battery seperate form the phone.
Sidekick Id battery Charger
Posted on Sep 23, 2008
Sometimes you have to give it a half hour or so of innitial charge
Posted on Sep 11, 2008
4 Suggested Answers
  • 18 Answers
SOURCE: trouble with sidekick id b
make sure the battery is properly inserted/.
Posted on Jan 02, 2008
  • 5 Answers
SOURCE: Sidekick ID.
try a friends battery if that doesnt work then dont buy a battery and sometimes reseting the phone may work like turn the screen to 90 degress and put an earing or pin inside the reset whole
Posted on Mar 28, 2008
SOURCE: SIDEKICK ID IS BROKEN
well the problem is the sidekick not the battery i suggest using ur battery in a friends id or 2 or 3 and see if it works if it does well that sidekick id is no good
Posted on Sep 29, 2008
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
Jul 17, 2009 | T-Mobile Sidekick ID Cellular Phone
Battery
Nomad182-
So did you buy it new? If so take it back. If not, then you got a used one that has a bad charginfgport. The sidekick 3 is notorioius for it and the sidekick ID has an issue with it as well. The orange light comes on but the connection that charges the battery itself is broken. Check out www.cellulardr.com. They charge about 75 dollars for the repair or you can do a workaround that charges the battery seperate form the phone.
The following link shows it for the sidekick 3 but the sidekick 3 and sidekick ID batteries are the same.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
I would also recommend a second battey so you can have one charging at all times. They runa bout 5 dollars on ebay.
Nov 11, 2008 | T-Mobile Sidekick ID Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID.
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick 3 wont turn on
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
Feb 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
you phone needs to be reflash, take the phone to a mobile service provider and have them replace correct the issue.
Jan 27, 2008 | T-Mobile Sidekick ID Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
112 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
