Question about HP OmniBook XE3 Notebook
Will not boot
It saids a file corrupted i lost my system disks
  • tanay1989 May 11, 2010
    Hi, albertcypres,
    Can you please elaborate your question more?
  • 3 Answers
Is this when you first switch on what is the exact message ? are you sure the laptop is reading your hard drive ?
Posted on Jan 06, 2009
Need to reboot computer,windows98,invalid disk error
You have to go into your BIOS and select booting from Disk not hard drive when i say disk i mean either the cdrom or dvd disk players attached to your motherboard. also you can get a boot disk to try that at the link below.
http://www.allbootdisks.com/download/98.html
Apr 07, 2012 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
What's your problem? My Acer Aspire One says "No bootable device -- insert boot disk and press any key". The problem is there is no boot disk available unfortunately.
Wow, this usually means:
  • there is no hard drive, or
  • operating system or
  • key files in windows are corrupted or
  • your disk has been damaged or has a mechanical failure.
If your computer takes 25-30 minutes to boot up, you have obvious windows or hard drive errors or corrupt data.
You can check this hint on disk errors but my guess is you have lost your disk and all the data. You might be able to put the disk into a second computer and retrieve some data.
Check: http://www1.fixya.com/support/r10602176-disk_drive_may_failing_or_disk_boot
I do this for fun and feed back, not $$$$
Jim
Oct 06, 2011 | Acer Aspire One PC Notebook
Error code 0x00000024 (0x00190203, 0x871a6948, 0xc0000102, 0x00000000000)
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
You should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS . You can download it from
http://www.geekswhoknow.com/files/ntfsinst.exe
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reinstall Windows and select the full format during the install
Nov 14, 2010 | Computers & Internet
My Hitachi Microdrive 4gb hard drive seems corrupt, but my computer still shows photos as jpg files (about 1000kb) and jrg files(30000kb, impossible). When I try to open them, the computer shows "no file"...
H there this mean a file is corrupt and you need to repair the damage file,you can do this by using a recovery disk for the computer if you have one.If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it,please follow these steps:insert the operating system disk into the drive,restart the computer, press F12 and choose boot from CD save and exit.As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, this should solve the problem. But should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong.
Jun 16, 2010 | Hitachi Microdrive (HMS360404D5CF00) 4 GB...
I have a Win XP desktop that has a corrupt system file
If you know what file it is, you can try booting with a recovery disk - you can download the UBCD boot ISO for example - and copy it back.
Or, if you can enter at least Safe Mode, you can try running the SFC /SCANNOW command from the prompt.
Finally, ordinarily you can run a XP install on top of an existing installation without losing data. This is a last resort, though; some user personalization and info is bound to be lost.
Apr 16, 2010 | Microsoft Windows XP Home Edition
Dell dimension wont boot after power outage and stops half way through the boot page
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 12, 2010 | Dell Dimension E521 PC Desktop
Boot system error, insert boot disk..
If you are using windows,System files(boot.ini, config.sys, autoexec.bat, msdos.sys, io.sys) might have lost or corrupted accidentally. You can fix it easily by connecting your hard disk to any other system having windows. boot from the host computer's operating system. open my computer, select folder options from tools menu. select second tab (view) scroll down to uncheck "hide protected operating system files (recommended)" and click ok. now go to C drive. Now you can see the system files mentioned above. copy all the required files to your hard disks partition's root and shutdown. now take out your hard disk and connect to your computer and re-start.
another method is to make a bootable pendrive (visit: http://www.esnips.com/doc/0882f54e-3445-41b6-830d-e43fd7d02dc2/Active+Password+Changer+-+Boot+Disk+Creator
to download application to make bootable pendrive.) copy all the system files from another computer. boot your system using this pendrive and select option 3 to exit from the menu to prompt. copy all the files to your OS partition and now reboot. this will solve your problem (you may need to change bios setting to boot from usb). for further details you can contact av_balajee@yahoo.com
Mar 01, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Sep 10, 2009 | Computers & Internet
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
HP OmniBook XE3 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
