Question about Samsung TCC1340 13" TV
Tv turns on, but when you turn it off it won't turn back on.
Tv will turn on, and stay on, but if I turn it off ,or the power gets disconnected, it refuses to turn back on. Sometimes this lasts for days, and then it will turn on as if nothing was wrong, and even work normally for a time. As I usually just leave it on for weeks at a time, I'm not really sure how long it works normally. Also, I could be wrong, but it seems like if I leave it plugged in the odds of it working go down.
  • patrick duffy Mar 27, 2006
    Thanks for the speedy response.
    It's been out for about 30 hours now, usually it takes a few days for the power to work normally, and I'd gather it works normally for a few hours or even days as well.
    But once it's been on awhile, and it gets shut off, it usually takes awhile for it to turn back on.
    I'm not really in the position to get a new tv, so maybe I'll crack this sucker open and check it out. If anything good happens I'll report back.
    President:
  • 3,130 Answers
Sounds like its a cold solder connection somewhere in the set or a capacitor thats bad in the power suppy.. These problems are the most dificult to troubleshoot unless they happen all the time.sorry I wish I could give you more info..
Posted on Mar 26, 2006
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
