Question about Hobart D300 Stand Mixer
Transmission oil We laid our used Hobart D300 floor mixer dow on a cart for storage and the transmission oil leaked out. How do we refill it to the correct level?
  • 41 Answers
This unit uses grease if it is leaking out the grease has broken and needs replacing
Posted on Dec 09, 2008
D300 Gear Train in transmission
I believe you are missing the correct model number but look at these models HERE and you may find what you are looking for, HERE
Thanks John Tripp Appliance 911
Jan 23, 2014 | Hobart D300 Stand Mixer
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Nov 19, 2009 | Hobart D300 Stand Mixer
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
How do you change the grease in a D-300 Hobart Mixer?
Depending how old the mixer is they used to use oil,now they use grease.Regardless it sounds like a seal is worn.Where is it leaking from?
Mar 28, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Transmission Grease for A120 and D300
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Jun 13, 2008 | Hobart D300 Stand Mixer
Hobart D300 Stand Mixer Logo
569 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
