I have a 5 year old Toshiba TV that needs a flyback 23236645. I cannot find such a part. Is there a place that has one or is there another replacement option.
  • jlee2222 Sep 09, 2008
    I have a 5 year old Toshiba TV that needs a fly-back 23236645.
    The suggested solution to phone Part Store and see if there is a replacement will not work as the replacement is no longer made. They suggested that it is unlikely that such a part can be found anywhere. Is this true or is there another option.
    I went into this site and it says that neither the regular part or the alternative part are available any more
  • 3,037 Answers
The part is available. You should be able to get the part from the following website
http://www.vancebaldwin.com/products/?23236645
If you have questions or need anything else, please let me know and I would be more than happy to assist
Posted on Sep 09, 2008
  • 10,594 Answers
Part not available at Part Store. but you can ask for supply at phone number listed.
  • Shahid Electronics
    Shahid Electronics Sep 10, 2008
    I already told you that required part is not available.
  • 13,433 Answers
The part is available here
http://audiolabga.com/mal_cart/mal_cart.php?nte=FT2990
TFB-4166BH FLYBACK TFB4166BH 23236645
Toshiba model 35D10 randomly turns itself off. requires unplugging/replugging at wall ooutlet to reset. problem has become more and more frequent.
replace flyback transformer (same type - equivalent will not work ) - this part's work is to supply voltage to TV TUBE - after 4 years ( 4 to 10 years - depending on usage ) this part becomes weak then in top brand TVs automatically TV senses this deffect & well in advance it shuts off TV to protect other components from getting damaged due to this flyback transformer ........... as on now in your case only flyback transformer is deffective - so replace it as early as possible ....... click below link for more details on how to replace it ......
http://www.fixya.com/support/t10123898-panasonic_ct_36hl43g_tv_just_turned
Oct 31, 2011 | Televison & Video
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
Oct 13, 2009 | Toshiba Televison & Video
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
I was told tthat the flyback is bad on my toshiba tv model #CF36G40 can i replace the flyback myself? Is there any adjustments that need to be made after replacement?
Stay the hell away from a flyback. It will knock you clear across the room! The only thing I look for in a tv is an internal fuse, and then I look very carefully. If I don't find a fuse, I toss it.
Apr 29, 2009 | Toshiba Televison & Video
Tv screen get smaller
not the flyback
it is either the vertical ic
or related caps
it is repairable probally between $75 and $100
what size screen and how old (is it worth it? that your call
Dec 20, 2008 | Toshiba 27A50 TV
Toshiba flyback transformer
Check this site: //http://www.globalsemi.com/search.aspx
Jan 22, 2008 | Toshiba CN36G97 TV
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Dark picture
you could be having a problem in your video circuit or your flyback transformer is bad have a tech look at it for repair.
Nov 13, 2006 | Toshiba 32A33 32" TV
Toshiba 35A44 - Dark picture on all channels and DVD's
for this brightness problem actually came out from flyback transformer...so, before you spend and waste your money, try to adjust at back of your tv first. But if you aren't an expert, better ask technician to do because that transformer supply a very high voltage....there's two adjustment point at flyback transformer, one point for focus and the other one for brightness! try first...
Nov 06, 2006 | Toshiba 35A44 35" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
