Question about Mitsubishi Heating & Cooling
Mitsubishi MUZ-A42ANA heat pump and MSZ-A42ANA indoor fan unit worked like a charm for over a year. Still does. But the condensed water removal operation (A wall mounted 2”x2” mini pump, Sauermann SI3100UN-23, 230v 50/60 Hz 18w, Made in France, removes water through plastic tubing from the indoor unit to the roof mounted heat pump 8 feet above) is making a vibrating noise each time it is activated, about every 30 seconds or so. Water is being sucked out, bubbles inside tubing and all, but the vibrating sound is a downer. Question 1: Is the mini pump the obvious culprit? Question 2: Is it normal to have air bubbles in the plastic tubing? Question 3: Is it normal to have condensation sucked out as often as 30 seconds apart? Thanks for your expert opinion.
  • 659 Answers
SOURCE: How to connect 230V,60Hz 2400 BTU Airconditioner in 115V 60 Hz
Impossible to do because the compressor is wired to use 230V. The motor on the compressor won't even run. You will need to have an electrician come in and check your breaker box to see if you can add a 2 pole breaker that will be needed to run the a/c. To add 230 volt, you will need to upgrade the wiring as well as the breaker. I wouldn't recommend you doing this at all! You risk killing yourself and or burning your house down. Hire a proffesional for this job.
Posted on Mar 20, 2009
t1m130
  • 86 Answers
SOURCE: Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Posted on Jul 08, 2009
  • 767 Answers
SOURCE: My Mitsubishi Mr. Slim heat
Here is the service manual for the model # you gave. http://www.mehvac.com/UploadedFiles/Resource/MSZ-FD09~12NA_Service_Manual_OBH497C_12-01-08.pdf
Posted on Feb 15, 2010
  • 12 Answers
SOURCE: The tubing for the condensation tube disconnected
You need a pro here because you could break refrigerant lines and that would be an even more costly repair! Go with someone who knows mini-splits.
Posted on Jul 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Posted on Jan 05, 2017
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Should the heat pump stop when it reaches temp?
Check to see if you have fan on automatic or continuous run ,it should have a setting so you can get air flow at all times or just when unit runs
May 18, 2015 | Mitsubishi Heating & Cooling
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
Mitsubishi Mr Slim Units Take 5+ minutes to start
this is not abnormal. you dont have to worry about the refrigerant freezing. it wont. Once your unit is given the call for heat it can take 5 minutes easily for the refrigerant to circulate and draw the btus from the ambient air. you can try to change the setting on your fan to medium but no higher.
Dec 11, 2009 | Heating & Cooling
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
335 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
