Question about Intel Motherboard
Spore killed ma pc
Hi was playing spore today for 10 mins and "click" ma pc switched of !!! now this has happened before and i leave it 5 mins and i can switch it back on. This time its like dead to the world. Ive cleaned it out with a hover ie plastic nossle lol Ive also made sure power is going into the power unit but im not sure whats coming out ie 12v or any volts as i dont have a multi meter. when i do power up and push in the start button the 2 fans in the base unit try and start for 3 sec's then nothing and i dont hear the hard drive trying to kick in either? my motherboard is Gigabyte ga-85661fxm-775
Ive been told reseting the bios might be the problem ? Help help help
  • 981 Answers
How did you check that power was going in, I wonder.
I rather imagine that something overheated and that produces your condition; resetting the BIOS is a likely solution rather than a problem, but you want to recreate the old settings....
   Are you not getting a beep code?
You should try to carefully reseat your videocard, and have your speaker hooked up so you can hear a beepcode if you get one.
I might suspect your power supply was overused also; unplug it a while and/or try a spare (being careful to replug the videocard too.)
Then make sure things are cooled right before playing again.
Killer app indeed.
Posted on Sep 10, 2008
Parked my Truck the next morning it was dead , what could be draining my batteries
Could be anything in the truck. The best way to narrow this type of problem down is to due a parasitic draw test. This is done by disconnecting the ground from the battery. Then connect an amp probe inline between the battery and terminal. Watch the amperage on the meter, it should drop to 5 ma or less after 10 min. This is sleep mode. If this happens you either don't have a draw (drain) or you have a draw that is that can't be duplicated at this time. If your amp draw is still over 5 ma after ten min. Something is staying on. To find out what that might be. Without opening any doors or actuating any switches, start removing and replacing fuses while watching amp draw on the meter when you see the amp draw drop you have found the circuit that is draining the battery. Hope this helps.
Oct 02, 2016 | Cars & Trucks
Ok I am trying to play a Game called Order of War and just when Im about to play the game closes and all I get is a box saying the game has stopped working this is not the first time this has happened as...
Perhaps you have to many processes running, I don't know the specs of your computer. Try shutting down unnessary processes in Task Manager or Try a program I use for older computers , freeware Razer Game Booster: http://www.iobit.com/gamebooster.html
Dec 24, 2012 | Acer Computers & Internet
Mold on botttom screen and gaskets of aGE dishwasher i used 1 cup of vinegar thru 1 cycle it is still there to be scraped off help
Using a dilute solution of 1 teaspoon chlorine bleach to 1 cup water, spray the screen and gaskets. Wait about 20 minutes to give the bleach time to kill the spores and bleach them. Then gently wipe with a paper towel or cloth towel. This should kill and remove the spores. THEN leave the door open overnight to let air circulate inside the dishwasher. If your mold problem disappears, continue to leave the door ajar once a week so that air can circulate. Mold does not live in open, airy spaces.
I hope this helps you. If it does, please come back to Fixya and rate my solution.
Jun 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Cylinder head torque settings for 1989 Volkswagen Golf?
hi to tighten you have to do it in 4 stages as follows
1st stage 40nm leave 5 mins 2nd stage 60nm leave 5 mins 3rd stage 90 degrees leave 10 mins 4th stage 90 degrees then you are done i will try put order on here i hope this works as follows
10 4 2 6 8 front of engine back of engine 7 5 1 3 9
starting with 1 so it goes like this
10 4 2 6 8
7 5 1 3 9
hope thats some help to you
Aug 09, 2010 | 1989 Volkswagen Golf
Golf iv 1.6 8v cylinder head torque settings
in that order hope this helps
May 10, 2010 | 1986 Volkswagen Golf
EA Game ''Spore'' - Videocard & Driver Issue
The card does not have the requirements to play the game. You would need to upgrade to a better video card if you want to play this game on your system. Sorry.
Jan 10, 2009 | Acer Aspire 5315 Notebook
Wont load the game
Shut the system down for 10 mins. at least and unplug too.
Let the system rest and then try it
Dec 11, 2008 | Microsoft Xbox 360 Console
For knowing warranty period
its time to replace the battery.
Apr 09, 2008 | HP Pavilion dv6000z Notebook
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
Intel Motherboard Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
