Question about Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
I was given a Canon AE1 and put new film and a new battery in and the shutter will depress but nothing happens. However, when the film is advanced it will take a picture. Any ideas?
  • gurukiki Dec 04, 2008
    I also cannot take a photo after advancing the film! When I press down the button to take the photo it does absolutely nothing!!!! However if I wait a few mintues and then go back and try again it works! Hopefully it is just dirt in the way of the magnet, and can be fixed easily!
  • Anonymous May 20, 2009
    Yes, very interested. Please do describe. And thank you for being so helpful
  • 667 Answers
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Posted on Oct 09, 2008
I am interested. I was having the same problem, but now I'm having problems after I advance it and try to take a picture, it does shutter. It usually works after a few minutes and i try to take the picture again.
Posted on Oct 21, 2008
I am having trouble loading the film into the camera(just been given this) I am not sure if the advance lever is working, or I am doing something wrong.
Make sure a fresh battery is installed so the shutter will fire. The advance lever move smoothly after the shutter is fired.
Feb 19, 2011 | Canon AT-1 35mm Film Camera
I cannot press down the shutter release and the film advance tab will not move, therefore making it impossible for me to take photos. Please help.
I guess it is actually an AE1 and not an EOS, as EOS is a digital camera! You will have to scrap the film in the camera by opening the back and removing the film. Take out the film can, then pull the film off the take up spool press the windback button on the bottom of the camera. This should get it working again. Try a few shutter releases and wind ons before putting a new film in. If you have important images on the film you don't wan to lose just do the above in complete darkness, and wind the loose film back into the can using the knob at the bottom.
Jan 04, 2011 | Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Apr 27, 2010 | Canon EOS-AE-1 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
341 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
