Question about Garmin StreetPilot c550 GPS Receiver
We have a Garmin StreetPilot III which is having a back lite problem. We can turn it on but the screen is so dark that we can hardly see anything. When we try to brighten the screen, nothing happens. Do you have any suggestions? Thank you Barbara Shaffer
It sounds like contrast.Turn on hit red light button (couple times.. maybe more)
push left side off rocker to lower contrast.
Good Luck
Rob
Posted on Oct 09, 2008
Garmin streetpilot 2610 does not turns on!!
There is no battery on Garmin Streetpilot 2610 so you have to plug it in !!!!
Feb 10, 2013 | Garmin StreetPilot 2610 GPS Receiver
Streetpilot III won't power on
The first solution is, of course, to try recharging your Streetpilot III by plugging it in to either your accessory outlet (cigarette lighter) in your car.......or a USB port on your PC. (preferably a USB2 outlet that has a higher power output).
Try charging for at least an hour with the 'other' cord, if the unit won't power up after using the 'first' one.
If the unit STILL won't power up after charging with BOTH cords (for an hour each), then either open the unit and replace the battery, or, sorry....if you're mechanically/electrically challenged......you're best to send your unit in to Garmin for repair, because it could be any number of different problems.
Michael
Feb 01, 2011 | Garmin Streetpilot III GPS Receiver
The 7200 gets hot when running and setting on the
Your best bet to resolve this problem will likely be with Garmin directly. They are excellent to work with and will be able to help either over the phone or provide you with an RMA for return of the GPS to the factory for repair. Contact them below:
http://www.garmin.com/garmin/cms/home/support/supportcontact
Dec 21, 2009 | Garmin StreetPilot 7200 GPS Receiver
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin 550 frozen screen will not turn off
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Aug 03, 2009 | Garmin StreetPilot C330 GPS Receiver
How to reset the Garmin streetpilot III deluxe
DO NOT DO THE FOLLOWING unless you know why you are doing it. If you press and hold ROUTE when the unit is powered up, you do a master reset. This will clear all data and user variables. Unlike previous Garmin GPS receivers, this will NOT clear the temp compensation curves and non user data.
If the MENU key is pressed and held when the unit is turned ON, an undocumented test screen is activated which incidentally measures battery voltage, temperature and a few other things. Pressing QUIT (several times) from the test screen gives you a set of display test screens.
Mar 27, 2009 | Garmin Streetpilot III Deluxe GPS Receiver
Cannot see screen but it turns on
Have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual which is available online at garmin.com /support /downloads
You might try this... point a bright flashlight at the screen while it's ON, but dark... see if you can see the normal screens, but just dark. If so, you've got a LCD backlight issue. It could the backlight dimmer circuit got damaged somehow, and if a Reset dows not help, sounds like it's repair time.
Garmin 1-800-800-1020
Apr 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Bought StreetPilot III used, can't locate satellites
Are you using it outside or in your car? Mine will not pick up sats fron inside my house.
Yooper-Al
Jan 30, 2008 | Garmin StreetPilot i3 GPS Receiver
Garmin streetpilot 2620
Hold down Menu-Find buttons if you get this screen, your hard drive gone bad. Garmin charges $275 to replace your unit8863097.jpg
Aug 16, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
