Question about Pentax MZ-50 35mm SLR Camera
Shutter problems like several others on this forum i seem to have shutter wont open problems. it twitches and vary occasionaly works, when the shutter release is pressed. it was fine several years ago when i put it into storage. but as luck would have it, when preparing it for my daughters A-level course it's failed me :-( from reading this forum it sound likely it's a worn shutter motor drive cog? with a second hand model csoting approx £25 on e-bay, do you have any tips on self-repair (nothing to lose?), rather than expensive proffesional repair. i was mech/engineer in a previous life, so have a bit of tech knowlege. do you need specialist tools? can you get the spare parts easily/cheap? would really appreciate any help, thanks... Sean
  • seanbaker Dec 09, 2008
    The camera is a Pentax MZ50. i tried new batteries, and the contacts are ok. In fact i've had it in lots of bits, trying to locate the shutter drive gear, as i'm told it might be stripped (common problem with this model). but no luck i couldn't locate it, without a service manual / diagram. I've pretty much given up with it, and as there seem to be several on e-bay for £25-ish, i'll probaly buy a second-hand replacement.
    unless anyone has any other suggestions or a diagram i can view... it will be going for scrap shortly.
    thanks for trying anyway.
    New Friend:
I have a Canon t3i and I have a problem with my shutter speed, it opened the shutter but in order to close I have to press the button again so is my shutter bad? broken? or its a setting that I need to change? please help
Hega
Posted on Jul 18, 2014
    Scholar:
  • 185 Answers
Sean baker,
If the camera was working when you stored it and the shutter fires occasionally, it's probably battery corrosion. Clean the contacts with a pencil eraser,or contact cleaner tool.
What kind of camera ?
Posted on Dec 08, 2008
1993 Dodge Spirit Speedometer twitches
Hey maybe its time to replace the sensor?
May 11, 2015 | 1993 Dodge Spirit
Zenzanon 80
The lens does not have a shutter - that's in the camera body. The lens contains the aperture or f stop adjustment. It is done by injecting or retracting blades in the light stream of the lens barrel between the front and rear optics. Check the aperture blades to see if they move easily and open equally by varying the f-stop ring on the lens while looking through it. If not moving all the blades the same amount or it does not continue to restrict the opening as you increase the f-stop value, there's something wrong with the lens.
Are you sure you haven't accidentally activated any exposure compensation adjustment on the camera body?
Jan 10, 2012 | Bronica 80mm f/2.8 Zenzanon-PS Lens
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
Hi there, i have a samsung t190 and it keeps twitching!
You can have intermittent open wires in the cable. Try new cable yet? Unless there are bad solder joints where the connector is. Or it can be something in the logic board.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Samsung T190 19" Widescreen LCD Monitor
The shutter will not open.
i have a canon zr60a all seems to work fine but it seems to have the shutter closed and ive tried everything .can anyone please help i bought it from a lady needing to pay a bill wonted to help but seems she stuck it to me ....lol now im the one needs help thanks chaz114@hotmail.com
Nov 16, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Same problem with Canon S2IS - Image is black, getto fix no longe
I had the same problem here in America and had a run around from Canon, but they finally took my S2 IS in for a checkup and found the problem so many S1 IS and S2 IS had with the symptoms you have. It was the shutter sticking. Mine was only a few months out of warranty and they did a free one time courtesy repair they say. Many in other countries have to pay to get it repaired. Canon should have recalled it as they did on the S1 IS. They did not! The way to know it is a sticking shutter is to look down the lens with something to magnify the opening and you will see the shutter stuck closed and nothing happens except the shutter sound. The display shows a blank picture taken. All menus worked fine. There is a forum about this with hundreds of Canon owners frustrated about it.
Sep 05, 2009 | Canon PowerShot S2 IS Digital Camera
Boiler makes twitching sound and doenst stay on
If the boiler uses oil (#2 fuel diesel); there are several factors that could cause this problem:
* Lack of oil due to clogged oil filter or restricted oil line.
* Cad resistance greater than 1500 ohms.
* Defective Primary control.
* Shoot accumulated on the retention head.
* En pinching flame in combustion chamber.
* Collapsed combustion chamber into firing range.
* There are other reason not listed here.
* Some problems require expensive testing equipment to make an accurate diagnosis.
* Get in touch with an oil burner technician with several years of experience. I have a license to practice in the state of Massachusetts. My number is 978-5443783
Mar 05, 2009 | Water Heaters
Shoots blank (dark) pictures after switching on.
This is a known design defect in the cameras and Sony is repairing them, even if your warranty is expired.
see this for Konica Minolta's official statement:
http://ca.konicaminolta.com/information/20070202/01_en.html
it'll direct you to a sony page where you can sign up to get your camera repaired!
more info can be seen here:
http://www.dyxum.com/columns/other/First_Black_Frame/First_Black_Frame.asp
Nov 12, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Group portraits with fluorescent lighting
Appature settings are never precise because they constantly need to be adjusted to suit the individual lighting conditions, in other words it is impossible to make a blanket statement for the best fstop and shutter speed to use for florescent lighting since that would depend on the size of the room ambient light the number of florescent lights and the distance to the target. As a rule of thumb these cameras have reasonably good light sensors so setting them to auto and pressing the button halfway should show you a display of the recommended fstop and shutter settings. I would recommend then bracketing from these settings. Bracketing is the process of taking several shots while varying the exposure settings to "passthrough" the optimal settings. Usually if you have a good idea what exposure will work a three step bracket is all that is required.
Example (based on outdoor exposure):
Optimal settings show shutter at 500 fstop at 16
Bracket picture 1:
shutter 250 fstop 16
Picture 2:
Shutter 500 fstop 16
Picture 3:
Shutter 1000 fstop 16
There is also a handy rule of thumb for exposure settings
Note that this also changes based on type of film
See the following chart for iso 400 film fstop of 16:
Bright sunlight: shutter 1/2000 th or just 2000
Partly cloudy: about 1/500th or 500
Overcast:1/125th or 125
Medium source (open window on a sunny day): 60
Inside light: 30
Low light: 15 up to 1"
night: varying
Hope that helps
Mar 06, 2007 | Canon EOS Rebel K2 35mm SLR Camera
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Pentax MZ-50 35mm SLR Camera Logo
313 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
