The colors (RGB) are separated on my Samung projection TV.
This is caused by a faulty convergence circuit. This would run around $300-$500 to have a repair man come and fix it.
Posted on Sep 11, 2008
Screen splits into 3 separate images not convergence
Make sure you re-adjust convergence in HD and non HD modes if your TV has HD
Mar 30, 2013 | RCA HD52W59 HDTV Projection Television
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
Does not work on hdtv cable
there are settings within a cable box and your tv that control how your tv set separates colors and images. try finding something in the settings that mentions rgb output/input
May 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rgb will not align
Go to Menu then to setup do you see convergence Listed ,if you do not then you have a Blowed Fused
FL231 it will be Located on Deflection board on right hand side of FBT flyback Transfomer there is 3 in a roll they are small looking brown rectrangler caps it will be the one in the Middle, These are Fuses.06 volt
Partstore.com has them. Let me know if you need more help.
Mar 23, 2010 | RCA D52W23 52" HDTV CRT TV
Blue splotches on the screen what is it?
hi friend,
Computer monitors work the same way. Here's a few web sites that list proportional colors:
http://web.njit.edu/~kevin/rgb.txt.html
http://www.tayloredmktg.com/rgb/
http://www.web-source.net/216_color_char…
or just plug "rgb colors" into Goggle.
There's more than you may want to know about it here:
http://en.wikipedia.org/wiki/RGB thank u for using fixya regards, sivaranjini
Aug 15, 2009 | Mitsubishi WD-62526 Projection TV
No green color in picture?
its a simple fix. just go to your menu in TV adjust the RGB color. balance the RGB settings.
May 26, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
