Acer Aspire One  PC Notebook Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Logoff after login in window xp - Acer Aspire One PC Notebook
Najib Safi
Level 3:
Guru:
  • Master 561 Answers
  • Posted on Aug 29, 2011
Najib Safi
Master
Level 3:
Guru:
Answers
561
Questions
0
Helped
64786
Points
1317
Your system has been infected by virus/Trojan. try if u can login through Safe Mode. if not do repair installation u will be able to login then scan your computer with the latest Anti virus.
How do I logoff on yahoo mail on the verizon droid? I see everything but logoff
You can Logout / Login by scrolling down to it. Located at the Bottom.
Set My Location Sign in ' Settings Privacy ' Legal
I hope thats what you mean.
How do I logon as administer
The built-in Administrator account is hidden from Welcome Screen when a user account with Administrator privileges exists and enabled. In Windows XP Home Edition, you can login as built-in Administrator in Safe Mode only. For XP Professional, press CTRL + ALT + DEL twice at the Welcome Screen and input your Administrator password in the classic logon window that appears.
To have the Administrator account displayed in the Welcome Screen, try one of these methods:
Method 1: Using TweakUI Power Toy for Windows XP Download TweakUI from here: v2.00 for Windows XP | v2.10 for XP SP1 and above
Open TweakUI and click "Logon" option in the left pane. Put a checkmark against the option "Show Administrator on Welcome Screen". Click OK to close TweakUI. Logoff and see if Welcome Screen lists Administrator login. Changes are immediate and you can use the Winkey + L to switch back to Welcome Screen to see Administrator account is listed.
Use this procedure to hide/unhide any user account from the Welcome Screen. Please remember, you can still login to a hidden account using CTRL+ALT+DEL classic logon method, but cannot Fast User Switch to a hidden user account.
Method 2 - Manual registry edit
  • Click Start, Run and type Regedit.exe
  • Navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  • Use the File, Export option to backup the key
  • Create a new DWORD Value named Administrator
  • Double-click Administrator, and set 1 as its data
  • Exit the Registry Editor.
For Windows XP Home Edition While you can configure Windows XP Home Edition to show Administrator account in the Welcome Screen, you cannot login as Administrator in Normal mode. Visit the following link for more information:
Error Message: Unable to Log You on Because of an Account Restriction
Please post your feedback and Vote if the problem resolved as per your satisfaction.
2answers
When my computer is turned on it shows the blue login page, when i click on the login icon, it goes to log-in but logs out automatically by itself.
Hello jwbandit402,
Try booting the computer into "Safe Mode" by pressing the F8 key at startup and see if it will continue with the login process. If not try performing a "Repair Installation" with your Windows Install disc to repair any corrupted system files that may be keeping you from logging in.
Hope this helps. Don't forget to leave feedback. Thank you.
1helpful
Windows XP HE on 505GR logon/logoff
it seems to be issue with windows. try logging the computer in safe mode , safe mode with networking then you have to copy mandatory profile to the current user logged in
2helpful
2answers
Immediate logoff after login
Try this
1. Boot using your winxp cd.
2. Enter recovery console.
3. at the command prompt go to
C:/windows/system32
4. next type:
copy userinit.exe wsaupdater.exe
5. exit and reboot normally. You should now be able to logon. But you're not done yet!
6. run regedit
7. find the Userinit key in:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsNTCurrentVersionWinlogon
8. modify the entry:
C:WINDOWSSystem32wsaupdater.exe
so that it reads:
C:WINDOWSSystem32userinit.exe
Windows XP sounds
Solution is already given above
Loging in on windows xp
Here is the solution to the logon - logoff issue in Windows XP.
(assumes that problem was caused by Malware called BlazeFind)
Enter the Recovery Console
Boot the system using the Windows XP CD-ROM. In the first screen when the Setup begins, read the instructions press "R" (in the first screen) enter the Recovery Console. Type-in the built-in Administrator password to enter the Console. You'll see the prompt reading C:\Windows (Or any other drive-letter where you've installed XP)
Type the following command and press Enter.
CD SYSTEM32
(If that does not work, try CHDIR SYSTEM32)
COPY USERINIT.EXE WSAUPDATER.EXE
Quit Recovery Console by typing EXIT and restart Windows.
You'll be able to login successfully as you've created the wsaupdater.exe file (now, a copy of userinit.exe)
Now, change the USERINIT value in the registry (see Phase II in this page) and change it accordingly.
Phase II - Fixing a registry entry which causes the Quick Launch issue (not retaining the settings)
Click Start, Run and type REGEDIT. Navigate to:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ WindowsNT \ CurrentVersion \ Winlogon
In the right-pane, change the value of Userinit to "C:\WINDOWS\system32\userinit.exe,"
Type the above value exactly as given, including the comma - exclude the quotes. Also, change the path to userinit.exe appropriately if Windows is installed in a different drive.
Close Registry Editor and restart Windows. The Quick Launch settings should be retained now.
No rights to run control panel requires new instal need media
1. to gain rights do the following.
Rebooting my laptop
How to reboot a laptop. In windows Xp, select start, then click on the "shutdown/restart/logoff" button. The machine will ask you : restart ? shutdown ? logoff ? You will select the "restart" option :P
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
