Question about Toshiba Satellite A75-S226 Notebook
A75 s226 wont boot
Loud spin noise hit f2 says no hard drive 60 bucks for new hard drive not bad if thats whats wrong. could it be the motherboard
    Scholar:
  • 97 Answers
If it says that the hard drive is not detected, then most probably its a busted hard drive. I doubt it's a motherboard issue since it was able to tell you that it can't find a hard drive. Plus the fact that there are spinning noises which can only come from either the hard drive or the fans.
Posted on Sep 17, 2008
I have a HPDV9000 Laptop and it is making a terrible loud noice, very annoying. Starts when turned on. What can it be. Thank you.
More than likely it's one of the cooling fans. They spin at relatively high RPM and if they're damaged they can emit a loud whirring or screeching noise. If it's a clicking noise then it could be your hard drive failing.
May 04, 2011 | Computers & Internet
Washer motor makes lots of noise as its trying to spin. Hardly spins at all with wet load. Spins slowly and still makes noise when spinning with drum empty. Does this mean the motor is bad or is it the...
If it is a really loud noise that drives you out of the house then probably a bad bearing. If that is the case then time for a new machine. Also check for something caught between the tubs.
Dec 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My acer wont load when i first turn on, or load,gives 2 loud beep
Sounds like the hard drive is going bad. Take out the hard drive and see if the laptop behaves like that if it doesn't then you know the hard drive is bad. If it still does then it could be a motherboard problem.. With it making those beeping noises when you first turn it on, they keyboard could be going bad because that would make a laptop start beeping like that as well.
May 19, 2010 | Acer Aspire 5100 Notebook
Loud Whining Noise from Motherboard on Startup
Whining noise is something in motion or moving.Does the graphics card have a onboard fan?Is it clean and free moving.
How about the processor fan? clean,free from wires or anything hitting it.?
Disconnect hard drive and see if you get the sound.
Jan 18, 2010 | Abit IP35P Motherboard
My front end is making very loud noises every time
same thing thats wrong wth mine ur bushings r bad. replace ur upper and lower ball joint and dont no proper name 4 it but outer tie rod goes to bushing on wheel change it.thats what im trying to figure out how to change.good luck
Jan 07, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Changed front left hub assembly on a Mercury Mountaineer 97 and now there is a loud noise when we drive forward but no noise when you back up. The noise was not there till the hub assem was changed also...
when i hit a curb with my 97 cavileier and bent the center hub its made a noise something like the one you are describing i changed it to a new one and there was still a slight noise i took it back of and took a closer look and the new hub had a slight warp to it so i took it back got another one and no noise i think that your hub maybe faulty as well dont mark my words but it worked for me
May 20, 2009 | 2003 Ford Focus
Acer aspire4920 makes loud noise at start up
This could be caused by the harddrive. There might be a bad bearing or something. Please backup all your data. You will probably have to replace the hard drive sooner or later.
May 07, 2009 | E-Machines T6524 PC Desktop
Compaq armada m700 making loud noises
Could be hard drive, bad speakers, or even a bad sound chip on the motherboard. what kind of noise exactly is it??
Does it make the noise while playing music or anything else??
Dec 23, 2007 | Compaq Armada M700 Notebook
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Im having serious probs here
first, ensure that only one master hard drive is connected (also disconnect cdrom(s). Next, at startup press the key (DEL or F2) to BIOS screen. then make sure that only the master hard drive in position 1 is listed or choose AUTO detect. now reboot and report if any progress. If no further progress, then master hard drive has failed somehow, but to be certain, try that drive on another pc as a slave just to test spin-up.
Sep 08, 2007 | AOpen MX46L Motherboard
Toshiba Satellite A75-S226 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
