Question about RCA F27650 27" TV
RCA horizontal screen issue
My problem is horizontal.
can you tell me the steps to get to a menu that will allow me to manipulate those parameters?
thanks in advance
margarete0
  • alaman Dec 12, 2008
    I have this exact TV and the screen is not only streched out, but it's even more streched out in the corners. The view is shaped like an hour glass. It looks like it needs an adjustment on the pincushion and the horizontal shrinked. I tried the service menu and it didn't successfully solve the problem. If I just go ahead and take it to a repair shop, what will they charge me to fix it most likely? Oh btw, before this problem with the screen streching out, I also came accross this one problem with the screen having a blank spot (black line) about two inches wide accross the bottom of the screen. The funny thing is, this problem gos away for awhile when I unplug it then plugged it back in.
Although I was able to get into the screen adjustment menu by following the below instructions, I ended up having to have the "pincushion module and 2HV diodes" replaced along with a repair to the deflection circuit.
If you choose to try to system settings, good luck, but make sure to write down your original value before changing any values and make sure that you do not change Parameter #42 (value has to be 247).
Instructions:
  1. TV turned on
  2. Press and hold the "menu" button at the TV
  3. Press and release the "power" button.
  4. Press and release the "vol up" button.
  5. Release the 'menu" button.
  6. The initial security parameter displayed will be 'zero' Change this to '76'.
  7. YOU ARE NOW IN ADJUSTMENT MODE
  8. Use the 'channel up or down' to select parameter 'p'.
  9. Write down the old value of the parameter before changing.
  10. Use the 'volume up of down' buttons to change the barameter value.
  11. When you have made all the adjustments turn the set off to exit.
Note: The Horizontal size it parameter 21 and the horizontal position is parameter 15.
Posted on Oct 06, 2008
RCA 20F514TD has lost horizontal hold. How can I adjust this? I have found no button or menu option discussed in the manual or by searching.
Horizontal rolling is the fault to your TV I assumes. It is a circuit fault. It can't be adjusted by customer controls. Contact any experienced service technician.
Nov 26, 2012 | RCA Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    My problem is the screen the yahoo messenger goes sideways everything is sideways the icons too is on the rightside sideways even the start button ols help me fix this.thank you i still need to lift my...
    You may try these steps. If you are facing a 90/180 degrees rotation issue with your displayed screen, this can be either due to a problem with your graphic card or a wrong manipulation of the hot keys of your keyboard. This problem can be easily fixed if you follow the steps below:
    Solution 1
    • Step 1: With the Desktop screen displayed in front of you, use your mouse left-click to access the Graphic Properties? option
    • Step 2: Select the Rotation Tab
    • Step 3: Uncheck the box labeled Enable Rotation?
    Solution 2
    • Step 1: With the Desktop screen displayed in front of you, use your mouses left-click to access the Properties? option
    • Step 2: Select the Parameters tab and click the “Advancedâ€? option
    • Step 3: From the displayed list, choose the name corresponding to your graphic card model
    • Step 4: Select the Rotateoption and change it to 0 degrees or to the “normalâ€? mode.
    Solution 3
    You can also make use of the hotkeys to change the rotation of your screen
    Press CTRL+ALT Gr+Up/Down/Left/Right arrows
    Solution 4
    If none of the above solutions has solved your problem, this might be due to a bad configuration of your graphic card. I will strongly suggest you to contact a computer technician to fix this issue.
    I hope this works for you. Good Luck!
    Mongkey
    "Understanding explains better..." google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
    Jan 23, 2011 | Gateway Computers & Internet
    RCA TV picture bigger than screen
    if the tv width is ok try entering to service menu (do not use remote control) as follow:
    1) turn the set on.
    2) press the menu button and hold it down while pressing the power button.
    3) while holding down the menu button release the power button and press
    the volume + button.
    4) The screen will display a one line menu, on the left the parameter P00,
    and on the right the value of the parameter V00
    5) release buttons.
    6) using the volume + button change the right parameter until 76
    7) using the channel down button change the left parameter until 06 (vertical size)
    8) whith the volume + or volume - adjust the screen size.
    9) when your tv is OK back to parameter 00 using the channel up button.
    10) press menu button.
    and trouble solved.
    Mar 05, 2010 | RCA F32650 32" TV
    Track ball does not allow east scrolling; it only allows west, north, or south scrolling
    Try to change the horizontal sensitivity and vertical sensitivity of the trackball to 100%,to do this follow the below mentioned steps
    1)press menu
    2)select option icon
    3)scroll down and select screen/keyboard option
    4)select horizontal sensitivity and change it to 100%
    5) select vertical sensitivity and change to 100%
    6) press menu button and select save
    May 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
    VCR stuck on menu screen
    Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
    Mar 09, 2008 | RCA Universal Remote Control
    Horizontal rolling solution need more info
    rolling in the sense? what you mean?
    Feb 08, 2008 | Koss KS3161 System
    RCA HD52W59 Wavy lines
    Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
    Common Problem #1) Convergence has gone out
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
    Here are some pics of convergence problems.
    69189a5.pngSOLUTION #1
    What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
    Common Problem #2) CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    69189a5.pngSOLUTION
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
    Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
    56 rca hdtv
    ANy way you look at it you'll have to take it to the shop. A tech can use the secret service menu to adjust the vertical & horizontal size. Or you may have whopped up B+ issue, that could be hard to find so replacing the deflection board woul;d solve that, hope this helps.
    Aug 02, 2007 | RCA HD56W66 56" HDTV
    Open Questions:
    Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
    Feb 26, 2017 | RCA F27650 27" TV
    RCA F27650 27" TV Logo
    258 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
