Home | Zanussi | 24 in. DA6141 Built-in Dishwasher | Machine does not fil...
Zanussi 24 in. DA6141 Built-in Dishwasher
Problem for Zanussi 24 in. DA6141 Built-in Dishwasher
Machine does not fill with water
By BMcC on Mar 25, 2006
On starting any cycle, following the tablet droping, the nachine does not fill with water. The cycle goes through as nornam without water. Cosequently the dishes do not get washed!
Same Problem
Sep 02, 2008
-   Machine doesn,t fill with water. All the Lights flashing on left hand side. Machine doesn,t go through cycle. Suggested it could be water pump?
-   b19mon
Jul 21, 2008
-   The cycle goes through as normal without water.cosequently the dishes do not get wash.The dishwashing liquid just runs down the door.What can I do to fix the problem?-   m-hamblin
May 10, 2008
-   I have the same problem. My dishwasher starts and runs through the prewash, then drains and that's it. The dishwasher sounds as though it's trying to go through the whole cycle, but I don't get any additional water. Of course, my dishes are not clean and what's more - the heat from the element dries the dirt onto the dishes. Honestly, the dishes seem worse when they come out than when they went in!!-   swailo
Apr 23, 2008
-   water is turned on but no water goes into the dishwasher. I think the solinoid valve may be the problem but I dont know where it is or how to get to it. I am on a small island in the Bahamas.-   Guest
Nov 18, 2007
-   very little water come through when machine start then stop water filling ,wash cycle minute not change and machine keep running .solenoid got power all time checking with meter.-   patel sandip
Best Solution
posted on Mar 26, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3605 votes
I had a Zanussi d/w up until about 5 years ago and there were two perennial problems that required attention. First of all, there was a double solenoid inlet valve for the water supply at the back, one part was the main fill, the other was a supply to the water softener - big plastic lump in the bottom under the salt filler. The main fill solenoid would fail about every 2 years and I would buy a replacement directly from Zanussi for about £10. I believe the failure may have been due to the fact that the machine was filled from the hot supply. This was allowed in the specification but the higher temperature may have led to failure. (Side note) In any case, it is better to fill dishwashers with cold water anyway because during the initial part of the wash cycle proteins are rinsed off rather than being stuck on the items, and secondly, heating from cold increases the contact time of the wash detergent solution and also improves
results. If the solenoid controlling the supply to the water softener has failed, it may well lead to the phenomenon you are seeing because the regeneration cycle happens after the wash in most machines.
If you feel comfortable about using a mains tester(a neon screwdriver one would do) and can *safely* reach the solenoid with power on and the machine the right way up, then you could see
whether power is reaching the regeneration side of the valve or not. If it is, and water is not entering then you have the culprit.
Another area that affects filling is the level switch. Generally these are pneumatically operated device looking like a flat drum, about 8cm across and 1cm or so thick. They are generally mounted up high in the machine or door and have two or three wires
on terminals and a small flexible plastic tube leading somewhere into the wet area of the machine. As the water level rises, water goes part way up the tube and air above it operates the switch to turn off the water.
Sometimes there are two levels used and hence two switches inside this assembly working at different pressures. One could have gone. Another problem is that gunk can get in the lower part of the tube and reduce or block it from detecting. and generally this results in no filling at all.
Hope this helps!
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Zanussi 24 in. DA6141 Built-in
Questions and Unsolved Problems for Zanussi 24 in. DA6141 Built-in
Do you recommend Zanussi 24 in. DA6141 Built-in Dishwasher?
Answer
Answer
water not going in to machine some one told sister that it runs on a vacume system, one repair man... (More)
Answer
i have a Zanussi dishwasher that used to work fine but now the top rinser thing dont spin
Answer
We empted the dishwasher before the cycle was finished then left the door open for a few hours.When... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 14, 2007
machine keeps draining forever , the machine was dirty I rinse the tub . there was water also under the bottom tray so I cleaned.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi 24 in. DA6141 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
