Question about IBM ThinkPad T40 2373 Notebook
R40 Thinkpad CD drive
R40 Thinkpad - 4 years old - Windows XP -
CD / DVD player has been working until recently.
PC DOCTOR - does not list DVD as a device
WINDOWS EXPLORER - does not list DVD as a device
CONTROL PANEL / SYSTEM / HARDWARE / DEVICE MANAGER - does not list DVD / CD-ROM DRIVE as a device
Put CD in drive and close door - spins and read light lites - no software player popup on screen appears.
DISK is 95% full - cannot do defrag - not enough space
Fixes Tried:
Running latest files Norton Virus scan now ... do not expect detection
Turned off and reboot - 1 error displayed "Windows Defender... memory location listed with error message"
Rebooted with ACCESS IBM button - does not list CD / DVD player
NEW HARDWARE - ran with "new hardware installed" does not "see" new cd drive.
Hardware or driver problem? THINKPAD 760EL I TAVE A INTALE CD ROM THAT IS NOT IN THE F1 SETUP WHAT DO I NEET TO DO. SO I CAN BOOT FROM THE CD ROM.
JAMES
  • JAMES JACKSON Sep 09, 2008
    I HAVE A IBM760EL THINKPAD IT HAS A BUILDED IN CD ROM BUT THE UNIT WILL NOT BOOT FROM THE CD CAN
    YOU HELP THANK YOU JAMES
Installation instructions for dvd/cd combo for IBMLaptop.
If it is a direct replacement drive, exact size as old drive, then all you need to do is remove the old cd drive and slide the new drive into the slot until the back plug engages. Install new drivers as needed and any software that came with new drive. Hope this helps.
Jan 24, 2009 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Ibm thinkpad r40 laptop just installed new harddrive, powers up no operating system found..... reorder harddrive, still no change setup and booted from cd, no change when placing windows xp cd will...
The problem is that you need to boot up the laptop with the CD as the first boot device so you can then install Windows XP.
If you press F12 a boot up you will get a list of alternate boot devices oher than the hard disk as the first boot device, which was set up in the BIOS. Select the CD as the first boot device and when prompted press the space bar to start the CD.
Jan 07, 2009 | IBM ThinkPad R40 2722 Notebook
D drive lost
Hi and welcome to FixYa,
Initially, pls download this quick fix patch. This addresses problems such as what you are experiencing in both Vista and XP.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 18, 2008 | Lenovo Thinkpad T60 Notebook
IBM R40 hardware malfunction
press F1 on boot up and get into the bios, reset defaults and then chane the boot order to the CD/ROM, save changes, reboot and you should be able to install XP
hope this works
kind regards
Nov 18, 2008 | IBM ThinkPad R40 2897 Notebook
Problem with some keys of keyboard
1. Sourcing a keyboard is easy, check EBay. Fitting it is easy, two or three screws from underneath and a single connector takes care of that. I just did one, and the keyboard cost me 20 pounds.
2. If you don't use the CD / dvd drive, then consider purchasing / loaning an external cd / dvd drive, which you then connect via USB. You can then reload Windows from this new device, and it will serve any new computers you may have in the future. Expect to pay 20 to 30 pounds from any high-street retailer.
To boot from this device (which you would want to do in order to load Windows from it), you will need to access the BIOS, and change the 'boot order'. So you interrupt normal boot, by pressing F1 (could be different o your comp), and make the USB cd / dvd the first device in the boot list.
Good luck.
May 16, 2008 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40
I need the instruction on how to install a replacement DVD/CD player on my IBM R40 thinkpad Laptop.
Thanks,
Moses
Feb 22, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
    Sounds like more of a software problem, I've had my dvd drive only show up as a cd drive but i think that was only in windows 98? Many problems will start showing up when your disk is very full. Try deleting some old files until you have 25% free space (only 75% full) or 20% free (80 full) at the minimum, then defragment. I recommend using a 3rd party program such as Diskeeper, since windows defrag Isn't very good.
    If you can not free up enough space because all of your things are too important to delete, think about buying an external hard drive to back up too, or simply look for a bigger hard drive of the laptop and copy the old hard drives contents to the new one using something like norton ghost.
    Most likely you would need a laptop hdd to desktop hdd converter, which is like $5 or less, so you can copy the contents since laptops can only have one hard drive (usually). If you can't do this or don't want to try it, bring your laptop to a pc repair shop and they will transfer your data to a bigger hdd for you for a nominal fee.
    Remember, I do not guarantee this to fix your dvd problem, but it is a good idea to do it anyways to increase performance and reliability.
Oct 31, 2007 | IBM ThinkPad R40 2897 Notebook
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
Oct 31, 2007 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T40 2373 Notebook Logo
186 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
