Question about Toshiba e-Studio 350 Copier
Spare Parts in Johannesburg
Hi, I have discovered the solution for my problem related before: It was the Gear Drive of the Development Unit.
Now, who can advise me in how to find this spare part in Johannesburg (South Africa).
    Problem Solver:
  • 13 Answers
For the eStudio 350, unless you get a used unit, it's much easier to get the whole developer unit, the part number is 6LA76548000 and sells for about 550.00 USD.
Posted on Sep 11, 2008
Density adjustment
isbcomputer.com is a dedicated online store offers Printer Spare Parts, Formatter Card, Main Board, Power Supply Board, Flat Cables, Fuser Pressure Roller, Gear, Sensor, Scanner Units, HDD Parts, HDD PCB, Hard Disc Drive Spare Parts, Data Recovery, Refilling Products, Jet Image, Toner Powder, Toner Drum, Toner Cartridges, Laptop Accessories, Power Adapters, Computer Accessories, Computer Services, Computer Peripherals and many more Computer and Printer related products at one place with best prices.
Visit - http://isbcomputer.com
Dec 30, 2016 | HP LaserJet 1320n Printer
Hi, i am Florencio Valiente looking for grass cutter spare parts please help me to it. STIHL FS55C.. unit cranck shaft assembly, 1 set spiral gear asssembly pls. advice..
New Stihl are sold by the local dealers only per Stihl policy.
I couldn't parts labeled Spiral gear so that maybe just a description problem here.
As for the crankshaft you will need know which version you have. Affects ignition timing.
Feb 08, 2015 | Stihl Garden
RICOH MP 3350B ask for toner even having a new one
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Cable operated the problem is on spinning the wheel the speedo drive is not turning, what can cause this. do you have a diagram of the speedo drive assembly in the front wheel and parts descriptions
Hi, Niron for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Taotao ATM50 A1 scooter speedometer gear puck speedo cable replacement...
Speedometer trouble on scooter
speedometer gear box fix for honda cb cm motorcycles
Top results matching Bajaj Discover service manual Scribd
Bajaj Discover 100M 2014 service manual DOWNLOAD FREE FULLMANUALS COM
May 30, 2012 | Bajaj Discover Motorcycles
Error code sc 390 code richo aficio 2045
That error is related to a bed reading in a sensor of the Development Unit, called "TD sensor".
You can try to take out the development unit and see if there is dust of toner or even if the plug is broken.
The development unit is placed under the PCU.
Open the front door and you will see it.
If you can not see anything abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
Jun 02, 2011 | Computers & Internet
I have white horizontal lines through the text when printing A4 portrait. What can I do to solve this?
Look at your black development unit, if you see a white band on the development roller, remove the development unit, shake it and turn the gear of the development roller ...
Jun 01, 2011 | Ricoh Aficio 1224C Black and White Copier
Sc 441
There is no listing for this particular code for the 450 model. Every other model that uses this code indicates the development drive train is locked up. This refers to the assembly immediately below the photoconductor unit (contains the green drum).
This can be either the motor or gear/drive train at the rear of the machine is locked up with a bad/weak motor or gear train is worn out. The other possibility would be for the development unit is seized up or nearly so. This is the more likely problem. The bushings and shafts ultimately get worn down or bound up with the toner/developer. You can try disassembly and cleaning. Just be prepared for a messy job. Be sure to save all of the developer mixture and put it all back in when you reassemble it. Otherwise, you will need to replace it with developer (not toner) and recalibrate the machine.
Sep 15, 2009 | Ricoh Aficio 450 Copier
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
Error code
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC
393-
001
TD sensor error
during warming
up
393-001: K
393-002: Y
393-003: C
393-004: M
The development-unit drive
starts. TD sensor signal is 0.78
V or less.
• Loose cable
connection
• Positioning plate out
of place
• Defective TD sensor
• Development unit not
found
1. Turn the main switch off and on.
2. Check that the development unit is
correctly installed.
3. Remove the development unit and
check the connector on the rear.
4. Check the positioning plate.
5. Replace the development unit.
Hope this can help you , seems the problem is on the black development unit
Aug 12, 2008 | Office Equipment & Supplies
Sharp Microwave oven magnetron blown or faulty
You can e-mail the spare parts manager with your model number here: JHB023@seartec.co.za
Aug 06, 2008 | Microwave Ovens
Toshiba e-Studio 350 Copier Logo
186 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
