Question about Mitsubishi WT-46809 46" Rear Projection Television
MITSUBISHI WT46809 WON'T TURN ON
I REPLACED CONVERGENCE IC'S ON LARGE HEAT SINK , REPLACED STR F6628 DUE SHORTING ACCIDENT . STILL NOT TURNING ON. I JUST READ ABOUT THE 2 FUSES ON A SIMILAR QUESTION . GAINING ACCESS FROM FRONT FOR THOSE , ARE THEY MARKED ? ANY INFO IS HELPFUL !
    Scholar:
  • 173 Answers
Might say like f203 ... just look at all fuses on cov. board and see if wire inside fuses is blown apart .
Posted on Oct 08, 2008
Will bad convergance ic's keep my Mitsubishi
If one of the two stk-392-570 chips has shorted it will blow a pico fuse on middle board and set will not come on.
Plug set in, turn on, when green power light goes out on the front of the set press and hold both the menu and input (device) buttons for at least five seconds and release both.
Power light will blink a two digit error code: if 2,2 it is a blown pico fuse and the chips also must be replaced. I have start to finish step by step instructions that are available if the customer selects me to answer in the new Marketplace here on Fixya.
see attached photo of chip and also part of middle board with the green pico fuses.
10_4_2011_6_10_21_pm.jpgchips look like this but will have 570 number on them.
SD TECH
Oct 04, 2011 | Mitsubishi Televison & Video
I had the sears repairman out to look at my mitsubishi WS 55511 rear projection tv. My TV will turn on for about 5 seconds and then shuts off. He felt it was the convergence IC (I think this is the part...
Is it this STR-F6628 or the G? And 23 is horizontal deflection, but that means it could be in this circuit, you have to check shorts, if it's the For G I have them.
Feb 17, 2011 | Televison & Video
Power tv on and then it clicks and turns off
Most of the time there are one or more 5 amp pico fuses open on the power supply. The cause of them opening is the +/- 30 volt line shorting from the convergence circuit. If you take this repair on yourself and are familiar with a ohm meter, you can check the small green pico fuses in the power supply. Remove the power from the set, take the back off. The board in the center is the power supply and convergence circuit. In the center of the you will a transformer. Just to the left of the transformer you will small green fuses that look like resisters. They are marked on the board but are sometimes hard to see. If one is open for the 30 volt line, the convergence IC's need to be replaced. They are mounted on the back of the large heat sink and the board must be removed to replace them. When you remove the board, be sure to remove all the screws not only around the edges of the board but also in the center too. There are also screws on each end of the heat sink and on the blind side center foot securing a ground wire. On each side of the board there are plug clips that must be lifted. At the front of the board there are plug connectors that need to be unplugged. Once the board is removed the IC's are easy to replace. Remove them from the heat sink, Unsolder them from the board using solderwik. The Convergence IC's should be STK392-570. If there is only one, it is a STK393-110. When replacing them, I recommend using heat sink compound on the back of the IC's where they contact the heat sink. solder in the new IC's then attach the heat sink to them.
Replace the small pico fuse or fuses, they should be rated at 5 amps. Once all the parts are replaced, remount the board making sure the heat sink holes align with the board holes. Reconnect the plug connectors, Plug clips, and reinstall all the board screws.
I hope this helps,
Skyassoc
Dec 12, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I was given a Mitsubishi vs-50111 I was told all it needed was to be adjusted due to the color being out of alignment however i let the tv sit for 3 days and when i plug it in i get nothing when i try to...
You need to be concerned about the convergence board. This is the board with all the RCA jacks and RF connections. Pull this board out. You will see two very large cooling fins [heat sinks] with two large ICs [black with about 15 pins each. Marked with #392 ---] I don't know the exact# right now. Replace these Ics. And check the small resistors that stand tall next to theses Ics, replace if necessary! Let me know what you find.Thanks for asking me!
Aug 22, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Convergence problem I have an intermittent vertical convergence problem. I have to shut off the TV and turn it back on to get a normal picture again. Need to fix this problem. The TV is a Mitsubishi...
Good Day;
You have poor connections on your "convergence IC's. Middle board IC's on large silver heat sink. Redo solder before total failure. Good Luck, big IRISH.
Oct 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blue shadow
Good Day,jmurf1037;
Yes, you have a convergence problem.From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Aug 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WT-46805
Good Day, Bosjerry;
I believe the IC's are on the left of the TV, looking from back, the TV uses STK 392-040 (two) convergence IC's. They will be mounted on a large heat sink (large silver/metal) looking device.
Good Luck, big IRISH>
Aug 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Installing STK392-570 IC's on a Mitsubishi WT-46809
tburg05,
Whoever told you that the WT46809 took two STK392-570 Ic for convergence amps were absolutely - 100% correct... The amps are located at position number Ic8c01 & Ic8c02 on the board. Very difficult to miss too they are about half the size of a pack of cigarettes and 1/4 as thick. They are Mitsubishi part number 267p150010 and after replacing them you want to also check all the low ohm resistors in that circuit for the yoke return.
If you order them don't get them from ebay or some other less than ignorant place, our industry is loaded with chineese knock-offs that would last tem minutes in your set before failing again... Personally I'd order them from Acme Enterprises out of Florida, 800-575-9833 and know that they were Sanyo originals that way.
BTW: If you replace these yourself make sure to use a generous portion of heat sink compound on the new installs for heat dissipation.
Bill
Dec 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Need detailed instruction
No. Usual procedure== Check the IC's that are mounted to
the large heat sink on center circuit board.Part # Stk392-570 X 2.
Check fuses FA904 & FA905 in power supply-replace,if open.
If either fuse is bad, replace both convergence IC's.
If both fuses check good and both IC's check good with your
meter,then check all the other fuse devices in power supply.
After that, advanced diagnosis by an experienced TV tech might be needed.
Oct 20, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
