Question about Samsung HCN4727W 47" Rear Projection Television
HCN4727W with Convergence issues
Hi all,
I have a HCN4727W tv and the convergence board part number BP41-00045B has blown both STK IC's and some resistors and caps. The resistors and caps are too far burnt to recognize values. If anyone has a schematic or part listing here are the locations. ICZ101, RZ142 through RZ145, CZ141, and CZ140. Thanks in advance.
  • 934 Answers
The ICZ designations on that board are two Sanyo STK392-040 amps used for convergence. Rz142 through Rz145 are the yoke return circuit are 3.9 ohm 1/2w resistors. CZ140 and 141 are two electrolytic radial 22mf/50v caps in the feed circuit for those amps.
My question would be - and I've NEVER seen this, in my 30 years in electronics, what caused such a domino failure? The amps are basically LV fed by a +/- 24v line input. If the yoke(s) were to short shouldn't cause enough feedback to destroy the convergence board in the manner you've indicated here. That's a P58A chassis used in several models of the Samsung and Akai designs. Only trouble I've heard of with those boards are cooling and most techs have taken to installing cooling fans directly on the board, driven by the +/- 20v line. That drops the temp several degrees and allows the amps to operate at a much cooler temp. We rebuild those boards here on a daily basis and add the mods for greater reliability. But other than that the P58A is considered a bullet proof chassis.
Hope this helps!
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Posted on Aug 21, 2009
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence both the error codes are near to each check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- -------- or from ------ ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
I have a HCL473W with a 'concave' screen effect on 2 colors??
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try If you have any more questions, feel free to ask!
Nov 08, 2009 | Samsung HCL473W 47" Rear Projection...
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
HCN4727W Convergence issue
Repalce STKs with 392-040 resistors should be 3.9 ohms,also you might want to join Repairworld it is for members who have TV shops over 7,000 different shops / lots of good techs there.They will not put up with anyone just looking to repair there own tv .Sorry unable to help with cz140,141.will do some checking you also can order whole convergence board.
Sep 08, 2008 | Samsung HCN4727W 47" Rear Projection...
Blowing Convergence Amp Boards
either the DCU Digital convergence Unit or the velocity board are most likely the fault.
Jul 10, 2008 | Samsung HCN4727W 47" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Samsung HCN4727W
Convergence board shot. Cheap to fix yourself, board has two STK chips on it and is easy to get to.
May 16, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
273 people viewed this question
Jerry Greenberg
Jerry Greenberg
