Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Concave comvergence problem i believe
Tried flash focus no luck tech support said to unplug and wait still no luck
went to the manual adjust for the convergence but some will not converge mainly the top and bottom corners creating a concave (warping) effect with pink/purple and green shadows
do i need to call a tech?thanks dawn
  • rudy_barriga Sep 17, 2008
    i have a sony kp-51ws510 and the picture is bowed in at the top & bottom of the picture , yes i do know how to use a meter and i do know how to solder and desolder. what i need is a solution to this problem.
    thank you
    rudy at rudy_barriga@uhaul.com
    Novelist:
    Champion:
  • 203 Answers
Unless you can solder and use a meter then yes you need to call a tech, this repair should run somewhere from $300-$500. Let me know if you need more info
Tim
Posted on Sep 11, 2008
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Concave tv screen colors distorted just had tv repaired one year ago for same problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Concave looking screen and double lettering, color aweful
you need the following comvergence repair kit it comes with the replacement ICs and resistors plus step by step instructions on how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Apr 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi HDTV concave
maybe your problem is easy my friend,focus on the horizontal circuit and try to resolder it.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to resolve concave issues
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Thanks,
Sanjay
Jun 24, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Picture distortion
This should cost you about 300 to 400 bucks to repair. If the service wants more, they are ripping you off. The convergence IC's are whats bad in this set and both of them cost less the 30 bucks. Good Luck
Oct 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-53XBR45: Concave Picture
try a system reset
turn tv off,
on the remote
display, 5, vol+, power
when set turns on press 8 then enter.
tv will turn off, then press tv on turn turn back on.  See if this helps
Sep 25, 2007 | Sony KP-53XBR45 53" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
