Question about Saeco Odea Giro Plus Coffee Maker
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without problem.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Posted on Aug 30, 2011
SOURCE:
Saeco odea does not brew coffee, all the water goes in the drip pan
Hello, the water in drip pan is clea water ot coffee water?(brown). Take a pucture inside machine with no brew unit inside.
Aug 27, 2017 | Saeco Coffee Makers & Espresso Machines
My Odea Giro stops working when entering the brew pump cycle. When I run it without coffee it runs fine. When I add coffee it stops after the grind cycle. I have replaced the microswitches and cleaned the...
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Good luck
Jun 18, 2014 | Saeco Odea Giro Plus Coffee Maker
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Flashing dregdrawer and descaling lights
Descale in the water tank...press nd hold water button and the mechine will do the rest automatically u jst hv to turn on or of the water knop...drawer take it out and take out the brewing unit put them back again thats it.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
1,253 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
