Question about Canon PIXMA iP1600 Printer
Cannon pixma ip1000
Won't print even when ink tanks are full. Indicator light ... 5 orange 1 green blinks. It was just printing fine the other day.
Annie Lacuna
  • ALEJANDRO AZUELO Sep 25, 2008
    my ip1000 printer will not print. 7 orange blink occurs. what is the solution. tksl
..ip1000 questions..
..it's cleaning time, a simple if messy operation. You will have to clean the print head and the waste ink pads, and whilst there might as well clean all the other gunk as well..
..so how to do this ?
..power on, open front, let carrier slide to middle front, pull power cable, pull computer cable.
..Remove cartridges
..by hand slide carrier to left to below the grooves in the upper case front. Clip the grey print head retainer, it pivots to the printer back, it must go up in the grooves, then remove print head, it comes forward..
Posted on Jan 10, 2009
  • justawr Jan 10, 2009
    ok, after joining..
    ..cleaning the ip1000 continued..
    ..now remove the foam strip in the base, put in shallow alcohol bath,
    ..clean base of print head with alcohol, ear-buds to remove obvious muck, fill inside with alcohol, stand on foam strip in shallow bath, leave, change alcohol, stand in bath on foam, repeat till alcohol runs clean..
    ..while your there, clean waste ink pads and wipers in the following sequence..
    ..remove case end caps, these clip at the bottom and hook at the top..
    ..remove upper case, this has 2 screws at printer front, just behind the front, dark grey paper feed roller, get at from above, there are two clips at rear, just above the upward grooves on printer rear, access these with the dust cover open, and insert flat screw driver between white clips and grey retainers..
    ..now remove waste ink pads, on the white holder, machine bottom right, soak in alcohol, using earbuds and toilet paper, clean the ink wipers situated on the left of the waste pad carrier..
    ..clean up all the other gunk you'll find..
    ..swear to be a better person in 2009, who WILL keep their hi-tech clean..
    ..when alcohol runs clean, dry off excess alcohol on absorbsent paper,
    ..reassemble
    ..important notes
    ...avoid touching the copper plates on the back of the print head..
    ..all directions are given as if viewing printer from front
    Problem Solver:
I had the same problem before, try to follow the instruction below:
1. unplug your printer.
2. hold down the power button, then plug it.
3. release the power button
4. press it once again.
Posted on Sep 26, 2008
Install
Posted on Sep 23, 2008
My cannon printer ip 1600 the waste absorber full.How to replacement of new waste absorber,I have no Mony. Your advise to in this papper
Posted on Sep 16, 2008
  • tanpeng2007 Sep 16, 2008
    my cannon printer ip 1600 the waste absorber full.How to replacement of new waste absorber,I have no Mony. Your advise to in this papper
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
How do i fix "Waste ink full" to resume printing
Hello there
Canon Pixma iP4200, Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction. :
Look at the table below:
· 1 led- Orange – Service test print 1 times – Orange – Service test print
· 2 led – Green – EEPROM information print 2 times – Green – EEPROM information print
· 3 led – Orange – EEPROM initialization 3 times – Orange – EEPROM initialization
· 4 led – Green – Waste ink counter setting 4 time – Green – Waste ink counter setting
· 5 led – Orange – Destination setting (Press Power > Press Resume 3x) 5 times – Orange – Destination setting (Press Power> Press Resume 3x)
· 6 led – Green – Print head deep cleaning 6 times – Green – Print head deep cleaning
· 11-13 led – Orange, Green, Orange – Return to menu selection
· 14 led – Green – Left margin correction 14 times – Green – Left margin correction
  1. Turn off the printer POWER button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma ip1000 My green on light is flashing orange, how do I reset it?
How many times blinking the light?If it's 7 times the waste ink tank is full.Look here.
If not may the print head is defective.
Oct 12, 2009 | Canon Office Equipment & Supplies
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon i320. the light flashes green, orange. does not print. I tried resetting the printer but to no avail. What is the next step?
it means that waste ink is full,
do this:
How To: Reset Canon Printer
I have try to find out how to reset many canon printer in my office. I
was try to googling to find the best way and quickly how to reset it.
And in google I was found two way how to do it. With Manual Reset and
with Software reset. I will give some advice how to do that with first
method, yes manual reset.
On this point we will do this with my Office printer, Canon i255, i320, ip1000.
For i255, i320
Waste Ink Counter Reset.
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or Step This Step
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should
be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.)
should be green.
6. Release both buttons.
Canon PIXMA iP1000
Waste Ink Counter Reset Manual for Service mode
be orange.
should be green.
Nov 30, 2008 | Canon BubbleJet i320 Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon PIXMA iP1600 Printer Logo
454 people viewed this question
old marine
old marine
Corne Viljoen
