Question about Sharp Televison & Video
I want to order ooz-lcd-cloths, how do I do that
My Beko WMP601W wont drain, clothes come out soaking wet, also the draw keeps oozing with suds, all over the floor???
You need to check the drain pump is free of any obstructions, can you hear the drain pump operating?
The machine will need several short wash cycles to flush out the excess soap which is causing the suds.
Mar 26, 2017 | Beko Washing Machines
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Dec 05, 2014 | Pelco PEL-PMCL542A-S 42-Inch Liqued...
Texas instruments ti 30x cracked screen
The liquid crystal of the LCD is probably oozing inside the calculator.
I don't believe it is worth fixing. It will probably cost a lot more than buying one of the newer Casios, TIs or Sharps.
Oct 02, 2013 | Office Equipment & Supplies
Oozing a mysterious fluid into the drum
this may help:
http://forum.doityourself.com/kitchen-laundry-large-electric-appliances/292547-kenmore-laundry-system-dryer-grease-leaks-out.html
you can also check these:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 27, 2011 | Maytag Dryers
There's no picture, the LED light just blinks, nothing.
I opened the power supply unit, and found two blown capacitors (swollen, and oozing black stuff) It is easy to fix, if you keep track of where the screws go, because there are so many.
1) open tv, and tape screws where they go
2) open power supply unit, and check if any capacitors are swollen, and oozing black junk, even if its just a litte
3) if you find blown capacitors, look on the back of the board, and find out what hole, or socket the leads go into, they all have a number.
4) with a DEsoldering gun, remove the solder from back of board, its easy, trust me. I'm no tv repair man, but even I could do it.
5) write down how many microfarads the capcitor(s) are, and the corresponding hole number.
6) find replacement capacitors online, and solder back into psu
7) re assemble tv, and enjoy.
Nov 02, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
We want to make ooze but we can not find instrusiens for it
I think you will find the website http://www.gamesages.com to be of big help.
Thanks
http://www.mylive-tech.com
Sep 19, 2009 | Sega The Ooze for Genesis
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Mysterious gunge appears ocassionally on clothes
Could be bad bearing, leaking grease.  Open the back and see if grease is oozing from the bearing??
Mar 23, 2009 | Kenmore Washing Machines
HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
Apr 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Black ink cartridge
Try Cleaning the maintenace unit which Is located under the parked region of the cartridges ,left hand side of the unit. Soak up as much of the ink as possible and clean the wipers with a damp lint free cloth or towel.
Apr 25, 2008 | Lexmark X6170 All-In-One InkJet Printer
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
