Question about Hifonics Brutus BX 1605D Car Audio Amplifier
Me just asking
I hooked up my amp it almost caught on fire something is really messed up before it messed up i had a capacitor hooked up to it, maybe something in the inside is touching
    President:
  • 3,130 Answers
I need more to see what your problem is ??? what you mean you had a cap attached to it and almost caught on fire.?? and why would something inside be touching?? have you had the unit open?? as parts dont ussally move around and "touch" all by themselfs Please respond back with more info!!
Posted on Mar 26, 2006
SOURCE:
Power cord caught fire
I assume you survived the ordeal. Did your washer? I can't tell from here. Now what is the real question? I believe a diagnosis is in order here before something REALLY bad happens.
power-cord-caught-fire-epwetmasq2n0wnrof1fw5po3-4-0.jpg Don't be that guy!
Mar 04, 2015 | Washing Machines
Iana mini rewind crank not spinning when advancing film
If the film is advancing you do not have a problem. It may be that the rewind button does not actually spin when you advance the film, because if it did and you have something caught on it when you are trying to do so you could really mess things up. Really, the rewind crank may only visibly spin in one direction.
Apr 17, 2014 | Lomography Diana Mini Camera & Flash...
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
My swift 92 engine caught fire after short circuit as soon as I stopped from a very short trip. Fire was put out but wires & rubber tubes were damaged. Car even re-started after this incident. The...
it is really up to you. i had a 1988 ford thunderbird 2.3 turbocoupe that caught on fire spontaneously one day and i didn't replace the wiring harness but i did have an electrician repair the harness and it worked fine. but i can see why you would want to if you could afford the new wiring harness. i know that for my thunderbird it was about $300 for the main harness.
Jun 16, 2010 | 1992 Suzuki Swift
Jl audio 500x1 not working
Im not sure if you a very knowledgeable of car audio but first make sure the rca's are plugged in!!!! Then make sure the gain is all the way up on your amp, well atleast some of the way!!!!! Maybe they were real dirty and decided to cut your rca's somewhere in the car so they llok like there still hooked up but maybe they really aint!!!!! maybe your amp is fried!!!! But remember it worked fine when you brought it to them!!!! They are trying to stick ya man!!!!
Feb 24, 2009 | Jl Audio Car Audio & Video
I hooked up power to the playstation 3 and i went to go and hook up the uav chords to the tv for audio and picture and the playstation 3 was smoking and my tv caught on fire
sounds like a horrible short im sorry.
Call sony if you were under warrenty.
It sounds like you had a faulty power supply and it really caused a mess.
Why would your tv catch on fire though? Their isnt and source of power that travels through rca's that can cause a fire through your tv.
Mabye your Tv was faulty..
Give sony a call.
Good luck
if you need any more help ask away
Thankyou
Sep 11, 2008 | Video Game Consoles & Games
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Hifonics Brutus BX 1605D Car Audio Amplifier Logo
Top Hifonics Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
