You will need to connect the television to your computer with the vga monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps you
Hi there! Welcome to FixYa!
If you are using Windows 7 you can use the keyboard shortcut (windows button + P).
Then select Projector Only.
Works with any type of external display (VGA or HDMI)
Just let me know if you are using a different OS.
