Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK. Bottom half of the screen is normal. There is a white bright 1/2 inch horizontal line (just in the middle of the screen) that separate black upper half and normal bottom half. This TV was bought in 2003.
  • 5 more comments
  • Anonymous Nov 18, 2007
    My problem is the same as vova's - the top half of the screen is black, the bottom half is perfect and there's a white line between the two. I called the cable company and they said it's the tv and not the cable box. It's Saturday night so I have to wait until Monday to do anything.
  • Anonymous Mar 23, 2008
    Ya same problem here... did either of you two get it fixed or did you just end up buying a new one?
  • cdiesse Jul 05, 2008
    yes ! Same problem here ... I think Sony have pre programmed his TV trinitron tube to die after 3 years ... Hope there is a solution, but I don't trust Sony anymore for long life material.
  • skhusain Oct 21, 2008
    SONY KV-27FV310:
  • Anonymous Oct 25, 2008
    Same problem with my TV. Top half is black with botton half OK. I have called in a repairman. Will let you know what happens.
  • Anonymous Mar 14, 2014
    there is a black line when it is on one side shows the show the other side is purple
  • Anonymous Mar 25, 2014
    sony klv bx300 has horizontal lines at bottom of screen and a double picture
    President:
  • 3,130 Answers
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
You can get advise and instant cures for this sony kv-27fv310 television set at: http//fletchersite.com/documents/ask.html
The manual for kv27fv310 can be aquired by using the following link:
https://www.paypal.com/xclick/business=lardonna%40snet.net&item_name=Sony%20kv27fv310&amount=15.61
Posted on Oct 25, 2008
SOURCE:
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Half of the TV screen went black with a bright white line splitting the screen horizontally.
it's eather your Verticle output ic ... i dont know what the part number is but shude be easy to look up ...... or maybe your yoak (this would not be normal) ..... i would bet on the IC and maybe some captors no way to know without changing out the ic and seeing
Feb 15, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Oct 22, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
896 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
