Question about Kitchen Ranges
Magic chef model no. 9845vvv in the wall oven
Its a in the wall oven and f3 keeps coming up and the oven wont come on it just throws up f3 and beeps
    President:
  • 1,314 Answers
Replace the probe in the oven its the gold rod sticking out in the oven should be on the upeer left side
Posted on Sep 09, 2008
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
Oven wont come on f3 code magic chef gas range
Hi hardcaseone,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Oct 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Error Code F2 and F3 on Kenmore free standing stove model 71342
My Magic Chef oven keeps getting a F3 error
Dec 14, 2009 | Kenmore Ovens
Whe i set the oven to 350 it has an F3 and wont light. This is a magic chef gas pioltless stove
Hi ttommajor,
Hope it helps.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
F3 error on magic chef electrical range
Hi glrecu,
Hope it helps.
Sep 06, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Elec. Oven F3 error code
check temperature probe , if connection is good at connector then replace sensor
Nov 18, 2008 | Magic Chef CER3760 Electric Kitchen Range
Kitchen Ranges Logo
158 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
