Question about Samsung Digimax D53 Digital Camera
Need help I put new batteries in my camera and now everytime i press the power button it makes a loud beeping noise twice and wont turn on ??????? I dont know what to do.
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Posted on Sep 18, 2008
SOURCE:
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
When the power button is pressed, the screen lights up for a 1 or 2 seconds, makes a loud beeping noise then shuts down. I have put fresh batteries in it with no change.
make sure you are using the correct replacement batteries for the camera .check the user manual for the specified battery ,that could be a possible problem.
Apr 06, 2010 | Samsung S760 Digital Camera
Loud beeping noise when trying to turn laptop on
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
Nov 07, 2009 | HP Pavilion dv9000z Notebook
New camera with fully charged battery won't turn on
It may be something more serious, or your new batteries may be too low for the camera to work properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Samsung SL202 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Camera malfunction
mine is doing exactly the same arrrrrrrraaaaaahhhhh
Apr 25, 2008 | Olympus SP-350 Digital Camera
Camera beeps twice and then shuts off. Does let me look at pictures.
You have a "lens error". That is something that can only be fixed by sending it into Casio. I would call them first and they will tell you everything that you would need to send in. Their number is 800-706-2534 and then keep choosing option 1.
Jul 07, 2007 | Casio Exilim EX-Z57 Digital Camera
Samsung Digimax D53 Digital Camera Logo
102 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
