WHEN NAME AND NUMBER ARE STORED ON THE PHONE, WHEN YOU CALL SOME ONE YOU SEE THE NAME SHOWING, BUT WHEN THEY CALL, YOU ONLY SEE THE NUMBER OF THE PERSON AND NOT THE NAME LISTED IN THE PHONE. IF YOU SET THE PICTURE ID ENTRY WHEN THE PERSON CALL YOU DONT SEE IT EITHER. WHAT AM I DOING WRONG?
2 Other Users Have The Same Problem
Comment by NannysBEBE, posted on Feb 16, 2008
Incoming mesage shows contacts number not name. What is the solution to this?
Comment by BLUTANDER, posted on Dec 17, 2007
From my PC I bluetoothed ringtones in wav and mp3 format to my motorola v3. The phone received the messages but when played back this message is shown "cannot play. file corrupt". The same ringtones were bluetoothed to my sony ericsson W880i and the same played. Is my V3 virus infected. Please help. Thanks.
Was this solution helpful? Show your Appreciation by rating it:
Cynthia
the number you see when you get an incoming call, is the number that should be stored.
Assuming you do have everything right, contact the support for your mobile network to assist you, or the shop that sold you the phone and ask if theres an option to enable/disable that option.
Good luck
Comment by silly girl, posted on Apr 04, 2006
your phone. This error may be easily corrected if you perform a Master Reset on the phone. Please note that a Master Reset will take the settings of your phone back to the default settings but it won't delete any information you may have stored in your phone. To perform a Master Reset, please follow the steps below:
Press Menu > Scroll to Settings and select > Scroll to Initial Set Up and select> Scroll to Master Reset and select > Enter security code will display (The default security code is 000000) > Press OK > Press Yes > Wait until the phone turns off and on again on its own"
Hope you work it out ;]
Post a New problem for Motorola RAZR V3 Cellular Phone
Email this problem
Can you Help with these Cellular Phones problems?
Motorola V3 Address Book - is...
razor phone probllem
how to install a themes for my...
My phone won't dial out.
