Question about Canon PIXMA MP780 All-In-One InkJet Printer
CD-R tray for printing CDs and DVDs, with Canon MP780
I have lost the tray that needs to be inserted into the Canon MP780 printer, in order to print on one side of CDs and DVDs.
Is it possible to find a replacement?
Thank you.
dermot.peavoy@gmail.com
  • Canon Master
  • 5,259 Answers
Am going to send you the parts list for this printer it might help you track it down!
Posted on Mar 16, 2010
Cannon Pixma ip5200 Wont print labels for DVDs
In order to print CD/DVD directly, you must use Canon Easy Phot Print & put your disc on the Disc Tray and then insert to the printer. Then enjoy with the amazing printing
May 30, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
My hp photosmart c5580 won't print the correct ink color on dvds
Unless a printer is specifically designed to PRINT on CDs or DVDS, that's the problem. Usually a program called "LightScribe" is used to print on CDs or DVDs right in your DVD/CD Drive. For printers, use a Self Adhesive DVD/CD PAPER Label(s) that you can buy in the store. Inserting DVDs or CDs through a printer can really mess them up and Damage the rollers inside!
Jun 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do you print ONTO a CD on a Canon MX700 ?
You need a cd bender -- this is a device that is sold at better computer stores. It heats the CD/DVD to the proper temperature to bend through the printer. After the cd is printed you have to put it in the freezer for about two hours -- CD plastic is a special memory plactic that returns to its original shape.
You may have to be persistant when you ask for this -- I find that most sales people are clueless about these devices.
Hope this helps
RG
Apr 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Direct printing on CD
i too have the exact same problem and im sick to death of it...
somebody please help
Aug 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printing CDs using the CD tray - now won't work
sometimes those cd label print papers are too thick..and need to fed in one at a time
Feb 25, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
CD-R Tray rejected
Go to this site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13800#SupportDetailAct
Under Please enter your question: type in this.
How to change counter code to english Click Search.
Follow the instruction.
Enjoy!
please vote.....
Feb 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
101 people viewed this question
old marine
old marine
