Question about HP Computers & Internet
My computer comes on, but the monitor only the power light comes on. It sayes no input signal. Took the monitor and power cord to a friends house and they worked fine.
  • Anonymous Mar 25, 2014
    How can i tell if my monitor is missing a cord if the red power button is lit up or how many cords does it need
    Champion:
  • 200 Answers
Well its either the motherboard or the video card issue.
you will need to replace one of those and most likely will be the motherboard
Posted on Sep 09, 2008
Marshall sd monitor wont power up
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your Monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | Marshall Electronics V R84DP SD 84 144...
No video input
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 10, 2014 | Philips 190B6CB/27 19" LCD
Blinking on/off light.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 06, 2014 | ViewSonic VA1913w Monitor
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
Monitor stays blank power light blinking
In this case if you monitor say no input or no signal it means the monitor connector cord are not connected properly to the motherboard. Or if you have a video card you need to plug your monitor connector to the video card. Because if you a video card and the monitor cord are connected to the motherboard the monitor will not be display. So check the monitor connector if it is correctly connected.
Dec 02, 2009 | Samsung Computers & Internet
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
