I am working in AutoCAD 2000 and am getting a .dxf file created by the Trimble Office Geomatics software. When I open the .dxf file in AutoCAD my points will have the point number and the point description but not the point elevation. I can't get this node feature to appear in my drawings after using a .dxf file to bring in the points.
    Guru:
  • 859 Answers
I may be able to help in the most general of ways having used several autoCAD programs myself but not this version of AutoCAD itself.
When you are done with your drawing in Trimble, are you saving or are you exporting. Are you compelled to render your drawing upon saving or do you have to render before saving.
And, more importantly, do you have the option to Export your drawing and then select the Program to export to. Or, is this what you are doing already.
And lastly, for everyone who will respond to your post, and you'll get some good replies and some weird ones and some like mine that may just double check your process; What version of Operating System are you using and what Platform are you on, Windows or Mac. If you are using Windows, have you applie XPSP3 yet (this patch has caused a lot of off the wall problems for many people).
When replying please address those of us who have asked a question by using the format: Worldvet: my problem is strictly with AutoCAD 200, thanks anyway. By including the board name you will help us to understand to whom you are replying.
Thanks.
Regards,
Worldvet
Posted on Sep 09, 2008
    Genius:
  • 1,847 Answers
Why dont you check the Autocad 2000 : The Complete Reference that will definitly help you.
Error AutoCAD 2016
DWG Repair Kit is a program will show you how to repair dwg files online.
Here the link: http://www.dwg.repair/
Best Regards,
Roger Mason
Oct 07, 2016 | Computers & Internet
Autocad drawing in winxp cannot opened in vista
Yes, Its same as you saved MS word or any other office files in latest MS Office 2007 format and try to open in 2003 format. For your future use with all the office related and other softwares you should always try to save two files viz a viz one in the format which your sofware gives by default and the other in the older format which you will have to manually scroll down after saying Save as in your document below the box in which you type the name on which you want to save your file. You will get many options there just check the version of your school autocad and save it according to that version. If you can't go to the school now for checking. Just save diag1, diag2, diag3 .... likewise for all the available formats in your pc one of them will deffinetly open at your school.
Thankyou for using fixya free utility kindly rate my solution.
Jun 30, 2009 | Autodesk AutoCAD 2004 for PC
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
How to open office 2000-2003 PPT files in Office 2007
chk blind guess.......
change the formet PPTX to PPT then open it
or open it on office 2007 and save it in ppt format
Mar 28, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Office 2007: Windows Installer searches for Office 2000
It looks like a problem with file associations. The computer maintains a list of file extensions and the programs that will open files with such extensions.
Please go to the link below for details on changing file associations:
http://support.microsoft.com/kb/307859
Mar 24, 2009 | Microsoft Office Professional 2007 Full...
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
I have a .dwg file that cause AutoCad 2009 to crash when I attempt to open it. I think that the problem is a missing or 'orphaned' X Ref, but I can't open the file to 'unload' the X Ref. What can I do to...
Thanks for your response.
To fix the problem I redrew the componenet and deleted the offending file. I found that I could open the file with AutoCad LT but not AutoCad 2009 Mechanical.
Best regards
Trebleblank
Nov 06, 2008 | Computers & Internet
Lost drawing file
Punch will open only PRO files or PSH files
You can open the DXF files with a CAD program or Corel Draw. regarding the BMP files, you can aopen them with almost any graphic program, including MS Paint
Jan 03, 2008 | Punch ! Super Home Suite (695985)
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
