Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
2 GE REFRIGIRATORS SIDE BY SIDE GSS201EPHWW
I have 2 of these refrigirators. One is not freezing or making ice and the frigde side is not cooling. The other one is not dispensing ice or water. Can you please help me figure out how to fix them or if I need to order a specific part?
  • Anonymous Oct 02, 2008
    lost freezer
  • macsky21 Mar 16, 2009
    I have the same problem. The freezer does not freeze, nor does the fridge get cold.
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
SAMSUNG RB 1955 MY REFRIGERATOR IS NOT WORKING NTHE FRIGDE IS ALSO BEEPING N NOT COOLING WHAT CAN I DO CAN U PLEASE HELP ME N TELL ME WHATS WRONG WITH THIS REFRIGIRATOR THANK U AND THE FREEZER WORKS FINE...
Check the temp in the freezer it may be starting to go bad. If the temp is where it is set than you have an ice block. If the temp is not where it is suppose to be than chances are your start relay is going out. Iff you need further assistance please comment me back.
Jul 29, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE GSH25JFT
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
My fridge has begun to almost stop making ice. It
Unless it has a broken seal, the fridge is most probably lacking refrigirant or pressure is weak. First thing you should do is check that the compressor is switching regularly and normally. Check refrigirant pressure and re-gas if necessary.
Sep 07, 2009 | GE Q Series GSS25QGT Side by Side...
Fridge not cooling and making noise
MY GE ICE MAKER IS MAKING A LOUD NOISE, HOW DO I DISABLE THE UNIT BEFORE IT BURNS UP SOMETHING
Jul 13, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Freezer frosts up and stops cooling after approximately 2 weeks GSS201EPHWW
AUTO DEFROST IS BAD REMOVE FREEZER BACK PANEL CHECK HEATER CONTINUITY WITH REFR. UNPLUGGGED IF HEATER BAD ORDER HEATER KIT FOR YOUR MODEL
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
511 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
