Question about IBM ThinkPad T43 Notebook
Gateway 6846 wireless not working
The wireless was working fine until my puppy jumped on the laptop and rotated the screen 90 degrees. Unfortunately I tried just about everything to fix this without luck (using control, function & alt keys on just about everything). After finding out the correct way to fix the problem I must have somehow disabled the wireless because I can no longer connect (laptop says to turn on wireless when it is already on). Could you please help me fix my screw up? Thanks
  • kaimana Dec 31, 2008
    same problem with puppy jumping on keyboard and rotating the screen on my ibm t43 laptop. how did you fix the screen rotation problem?
Fn-f7 fixed the screen rotation problem on the ibm t43
Posted on Dec 31, 2008
    Problem Solver:
  • 10 Answers
Have you checked control panel is it showing at all, If it shows but has the yellow exclamation mark against it try removing it and then reboot your laptop should then find it and ask you to install the drivers. If it does this it should then work.
Posted on Sep 09, 2008
Gateway laptop computer screen is upside down and can not use mouse
Shortcut Key To Flip The Screen In the Windows TO 180 Degree..
The shortcut is (or should be, read below**)
for normal windows : Ctrl + Alt + <Up arrow> (or shift+alt+<up arrow>)
and for 180 deg it is : Ctrl + Alt + <Down arrow> (or shift+alt+<down arrow>)
However, you should know that these are default shortcuts for
Intel Extreme Graphics Controller, and you can change them. To
check / change or disable these keys go to control panel->Intel Extreme Graphics->Hot Keys.
**sometimes the shortcuts do not work. This happens when you have not enabled rotation
feature in Display Settings under Intel Graphics Media Accelerator media. You need to
enable rotation in order to be able to Rotate / Flip your windows screen upside down / 90 / 180 / 270 degrees.
Mouse: with mouse, do you mean a usb mouse or the mousepad? if the mousepad isnt working, check ur "F" keys for an icon that looks like a mousepad icon. Then press the "Fn" key + the corresponding mousepad icon key and see if it works.
Oct 15, 2013 | Gateway CX2610 Notebook
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
I need recovery disk for my gateway m-6846 laptop
Recovery discs for store bought laptops are individualized. You can usually order a duplicate set from the manufacturer of your computer for $10-$20. Here is what I found:
http://support.gateway.com/s/SOFTWARE/Medialess/FAQ/SUPPAGE01su44.shtml
Jun 03, 2011 | Gateway M-6846 Notebook
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
How do i do a system restore for a gateway m 6846??
Go the the start button>All Programs> Accessories >System Tools>Hit "Continue"....wait for the system restore screen to come up...choose the recommended restore point or choose your own, it will tell you what to do... and don't touch your computer while it is restoring.
Sep 10, 2009 | Gateway M-6846 Notebook
Display rotation on monitor
Hi, the shortcut to change the orientation of your display is:
<ALT>+<CTRL>+<ARROW>
Mar 18, 2009 | Gateway HD2201 22" LCD Monitor
Gateway m305crv laptop
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
May 17, 2006 | Gateway M305CRV Notebook
IBM ThinkPad T43 Notebook Logo
352 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Michael Vincent Cruz
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
